Site
Search
User
Site
Search
User
Forums
CPSR status back to C variable
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
349 subscribers
Views
Users
0 members are here
Arm7
Compilers
C
Options
More actions
Cancel
Related
Luken8r Luken8r
over 13 years ago
Note: This was originally posted on 17th November 2008 at
http://forums.arm.com
Im using the TI Code Composer suite with an ARM 7 and Im looking for a way to get the CPSR back into a C variable. I was looking through the documentation that came with the compiler and it didnt have quite what I was looking for. What Im looking for is the state of the interrupt disable bit. I need to use this bit as a condition variable for something like:
if (interrupts enabled){
do this
the inline asm syntax is just
asm("assembly");
The problem is, Im not sure how to associate some C variable to the asm code to pass the CPSR back to the C code flow. Ive used other compilers in the past that have an option to pass arguments to the asm code like
_asm("tfr b, ccr",foo);
which passes the condition code register (for an HC12) to the var foo, but this compiler does not have that capability. How would I do the above with this compiler?
0
Peter Harris
over 13 years ago
I don't know anything about the TI compiler syntax, but the assembler instruction you are looking for is the "MSR" (move to status register from register) and "MRS" (move to register from status register).
Cancel
Vote up
0
Vote down
Cancel
0
Peter Harris
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
