Site
Search
User
Site
Search
User
Forums
Arm11 clock
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
347 subscribers
Views
Users
0 members are here
Arm11
Options
More actions
Cancel
Related
Arm11 clock
korner korner
over 13 years ago
Note: This was originally posted on 13th October 2008 at
http://forums.arm.com
Does anyone know if there is a timestamp clock in Arm? Something like the RDTSC in intel?
Or some other high frequency clock?
I need a clock to mesure performance of my linux kernel (and I use the RTC for something else).
Thanks everyone!
0
korner korner
over 13 years ago
I will look more deeply in the CP15 documentation, maybe this will be my answer.
Thank you.
About the note: I need to test the linux kernel for a hard real time system. The RTC will cause an interrupt every 1 sec, but I need to see the biggest latecy that occur, and this how I could know how fast an interrupt will handle on the system .
I need to know exacty how many microseconds it takes.
Cancel
Vote up
0
Vote down
Cancel
0
korner korner
over 13 years ago
Thank you for your response and for the links.
I looked it up, and this is not exactly what I need.
I need to measure the latency of an interrupt (in my case, the interrupt caused by the RTC). So I need another clock to see how much time it took from the interrupt till I was able to read this clock.
I found a code that do exectly this, but use the RDTSC and I need to replace it with some kind of a clock in Arm.
Do you know this kind of clock?
Thank you very much,
Liat
Cancel
Vote up
0
Vote down
Cancel
0
korner korner
over 13 years ago
Thanks for the info. We know that linux isn't perfect for hard real time, but we would like to test it and see maybe it will be good enough for us.
What do you think is the best way to measure the latecy of the interrupt?
Thanks,
Liat
Cancel
Vote up
0
Vote down
Cancel
0
Peter Harris
over 13 years ago
If your SoC wires up the PMIRQ signal to the interrupt controller, you can use the performance monitor cycle counter to generate an interrupt on overflow.
The performance monitor cycle counter wraps on overflow, so you can measure how long it takes from the time the overflow occured (PMIRQ asserted) to the time that it was serviced.
Cancel
Vote up
0
Vote down
Cancel
0
Peter Harris
over 13 years ago
Linux is not ideal for hard real-time systems - even with the RT patch.
For an ARM11 processor worst case for something as large as Linux is exceedingly variable, and depends on things like whether the IRQ handler is in cache or not, and other memory system related activities.
Personal experience shows that interrupt latencies on Linux are in the order of 5000 cycles on an ARM1176 with a 2:1 core to bus memory ratio, and only a single layer of cache. A real platform might be significantly more cycles if the memory system is slow compared to the core.
Cancel
Vote up
0
Vote down
Cancel
0
Jacob Bramley
over 13 years ago
You can use the System Control Coprocessor (CP15) to perform performance monitoring. Under Linux, you'll need to do this from a driver so that you have access to a privileged execution mode.
Documentation for CP15 in the ARM1176 can be found [url="
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0333g/Bgbgbgeb.html
"]here[/url]. If you're using a different ARM11 (such as the ARM1136), you'll need to look around to find it.
[url="
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0333g/Bahcaafe.html
"]This page[/url] provides an overview of the performance monitor, but you'll need to fish around the CP15 documentation in order to find out how to use the registers.
Let me know if that's what you're after,
Jacob
Cancel
Vote up
0
Vote down
Cancel
0
Jacob Bramley
over 13 years ago
I'm surprised that CP15 doesn't do what you want, but I must admit that I haven't used the performance monitor stuff before.
It's likely that your processor has counter peripherals which may be configurable to do what you want, but you'll have to look at the documentation for the particular chip you have as I don't think that's architectural.
On another note: RTCs typically have an accuracy of milliseconds at best, and many RTCs only give a resolution of 1 second anyway. Does the interrupt latency really matter in such a situation? Consider a very slow system: A 100MHz ARM11 core with a 1000 cycle interrupt latency. 1000 cycles at 100MHz is just 10 microseconds.
Cancel
Vote up
0
Vote down
Cancel
