Site
Search
User
Site
Search
User
Forums
Loading instruction set
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
347 subscribers
Views
Users
0 members are here
Cortex-M1
FPGA
Address
Cortex-M
Options
More actions
Cancel
Related
chaitanya chaitanya
over 13 years ago
Note: This was originally posted on 7th October 2008 at
http://forums.arm.com
HI,
I am trying out the Cortex M1 on an altera FPGA. I have an example implementation from the Altera kit which uses ITCM to load the software files on the ARM. I want to instead load the software from external Flash or SRAM. I have made the required hardware and software changes and when I single step the system in emulation mode, it runs a few lines and jumps to 0xfffffffe, which is a hard fault location. The flash is off-chip and sitting on a tri-state bridge, the address location for the flash starts at 0x0 and the size is 0x1000000, so I know that flash is within the first 0.5GB of ARM's address space. Any suggestions why the arm is hitting hard fault.
Thank You
Chaitanya
0
Simon Craske
over 13 years ago
Chaitanya,
Assuming that the flash is correctly integrated, a common software fault that results in hardfault being entered almost immediately is not having the LSB of the second word set, i.e. the LSB of the reset vector must be one.
hth
s.
Cancel
Vote up
0
Vote down
Cancel
0
Simon Craske
over 13 years ago
Chaitanya,
hth
s.
Cancel
Vote up
0
Vote down
Cancel
