Site
Search
User
Site
Search
User
Forums
Cortex-M4: guaranteed wakeup from WFI?
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
Cortex-M
Options
More actions
Cancel
Related
Markus Grabner
over 13 years ago
Note: This was originally posted on 8th August 2013 at
http://forums.arm.com
Hi all!
I'm wondering how to ensure that the Cortex-M4 is always woken up on an interrupt from the WFI instruction when executing code like this:
__disable_irq();
// do something ...
__enable_irq();
__WFI();
If an interrupt is triggered between __enable_irq() and __WFI(), the interrupt handler is processed [font="Arial"]immediately and completed before [/font][font="Courier New"]__WFI() is executed, i.e., [/font][font="Arial"][font="Courier New"]__WFI()[/font] will wait for the next interrupt such that the first one is effectively lost. The ATmega* processors have a very simple solution to this problem: enabling interrupts is always delayed by one clock cycle such that the processor can safely enter sleep mode before interrupts can occur and wake up the processor. Thereby it is guaranteed that the processor is always woken up on an interrupt. How is this done on the Cortex-M4? As far as I know, there is no such enable interrupt delay, or is there a totally different mechanism to ensure wakeup on interrupts?
Thanks & kind regards,
Markus
P.S.: A lengthy discussion on a similar topic is
here
, though in German language.
[/font]
Top replies
Martin Weidmann
over 13 years ago
+1
verified
Note: This was originally posted on 9th August 2013 at http://forums.arm.com I don't tend to use the M class, but... Could you use WFE instead of WFI? WFE (Wake for Event) will cause the processor to...
+1
Martin Weidmann
over 13 years ago
Could you use WFE instead of WFI? WFE (Wake for Event) will cause the processor to wake on arrival of an interrupt (if they aren't masked) or an Event. Where an Event can be generated by executing SEV.
If you put a SEV instruction into your interrupt handler you'd know that the event register was set, meaning the next WFE instruction would "fail". As long as you have the WFE in a loop (re-checking the sleep condition on waking) this shouldn't be a problem.
Cancel
Vote up
+1
Vote down
Cancel
+1
Martin Weidmann
over 13 years ago
Cancel
Vote up
+1
Vote down
Cancel
