Site
Search
User
Site
Search
User
Forums
ARM with built-in AES cryptographic module
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
Cortex-M
Options
More actions
Cancel
Related
Javi Jap
over 13 years ago
Note: This was originally posted on 3rd October 2012 at
http://forums.arm.com
I want to implement a kind of dongle with an ARM and I need a processor that, given a password, generates the keying material. I am looking for an ARM with a built-in hardware encryption module. I have just found some information about the TrustZone module in some ARMs, but it has much more functionality, is more complicated than what I need and there is no information about any encryption module.
Can anyone tell me if what I am looking for exits? I have found it in AVR but I would like to use ARM if possible.
Thanks in advance!
javi
Top replies
Martin Weidmann
over 13 years ago
+1
verified
Note: This was originally posted on 3rd October 2012 at http://forums.arm.com TrustZone is about separating "trusted" software from "untrusted" software. So it's most useful in open systems. Say a smart...
0
Javi Jap
over 13 years ago
Note: This was originally posted on 5th October 2012 at
Thanks ttfn and Alban for your answers, they have been very useful, that was exactly what I was looking for.
I still have to think a bit more about all the functionality I need, but surely I will choose the STM32F415xx or one of the Atmel's SAM4L Series. I also have to see which development kits are available for each one.
thanks for your help!
javi
Cancel
Vote up
0
Vote down
Cancel
0
Alban Rampon
over 13 years ago
Good afternoon and welcome Javi,
The reason you only found references to TrustZone as opposed to AES modules (for instance) on ARM.com is because ARM doesn't create that module.
If you look at ARM Partner's microcontrollers, you will find some with AES modules along with an
ARM Cortex-M core
Here are ONLY A FEW examples:
NXP
LPC1830 with hardware AES and OTP key storage, based on ARM Cortex-M3
Freescale
Kinetis K60 Ethernet Crypto MCUs, based on ARM Cortex-M4
Atmel
SAM4L low power MCU with AES crypto engine, based on ARM Cortex-M4
Energy Micro
Gecko EFM32 with hardware AES, based on ARM Cortex-M series
STMicroelectronics
STM32 F4 with AES, 3DES, hashing, based on ARM Cortex-M4
Texas Instruments
Stellaris LM4F, with embedded AES routines (in StellaWare) based on the ARM Cortex-M4
Is there a special manufacturer you are looking for? I might have some boards available for you if you tell me a bit more.
Cheers,
Alban
Cancel
Vote up
0
Vote down
Cancel
+1
Martin Weidmann
over 13 years ago
TrustZone is about separating "trusted" software from "untrusted" software. So it's most useful in open systems. Say a smart phone - separating the OS with the various downloaded app from the payment software. Not sure whether this fits your use case.
In terms of the AES, it sort of depends on what you have in mind. You could just have a software algorithm running on just about any ARM core, not an expert but should fairly easy to get hold of. Performance is going to come down to how beefy a processor you then have. Or you get a separate hardware accelerator, using the ARM to just do the interfacing. In the second case, the ARM could be relatively small/low power. As it would essentially be maintaining the USB stack and managing communication with the AES block.
Cancel
Vote up
+1
Vote down
Cancel
