Site
Search
User
Site
Search
User
Forums
How to relocate the Cortex-M3 Vector Table
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
Cortex-M
Options
More actions
Cancel
Related
Davide Masi
over 13 years ago
Note: This was originally posted on 9th November 2011 at
http://forums.arm.com
I am Davide Masi and I work on Fujitsu based on ARM Cortex M3.
How do I relocate the interrupt vector table from address 0x0000 to a different address, for examples in RAM?
Where can I find examples or AN about the problem?
Top replies
Joseph Yiu
over 13 years ago
+2
verified
Note: This was originally posted on 11th November 2011 at http://forums.arm.com Let's say you want to relocate vector table from flash to SRAM: - reserve an area in SRAM for Vector table when you setup...
0
Davide Masi
over 13 years ago
Note: This was originally posted on 10th November 2011 at
Is possible to relocate the vector table also in run-time?
Cancel
Vote up
0
Vote down
Cancel
0
Davide Masi
over 13 years ago
What steps should I follow to reallocate the table of vectors?
Cancel
Vote up
0
Vote down
Cancel
0
Joseph Yiu
over 13 years ago
Hi David,
Welcome to the forum.
Maybe you can use the Vector Table Offset Register (VTOR) to do this.
http://infocenter.arm.com/help/topic/com.arm.doc.dui0552a/Ciheijba.html
Examples can be found in various forums by searching for "SCB->VTOR".
One example is on Keil forum:
http://www.keil.com/forum/17484/
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
0
Joseph Yiu
over 13 years ago
Yes, VTOR can be programmed at run time.
Cancel
Vote up
0
Vote down
Cancel
+1
Joseph Yiu
over 13 years ago
- reserve an area in SRAM for Vector table when you setup your project (tool chain dependent). This area need to align with the size of the table (see the link I provided in previous message).
- during run time, copy the vector table from flash to the reserved vector table area, and then modify the vector entry you need to change if required.
- write the new vector table address to VTOR.
Cancel
Vote up
+2
Vote down
Cancel
