Let's have a discussion on ARM-based IoT devices
Hi everyone!
I’ve been diving deep into Edge AI since some months, and honestly, the progress we’re seeing on ARM-based IoT is mind-blowing. moving a model from a powerful PC to a tiny Cortex-M controller is where the real 'fun' (and headaches!) begins.
I’m curious to know what everyone is using these days to keep their models lean and mean. I've been playing around with TensorFlow Lite Micro, but I keep hitting walls with memory overhead.
A few things I’d love to chat about some points. Is anyone else finding that ARM’s CMSIS-NN gives that extra 'oomph' in speed over standard kernels? Do you guys find the jump from 16-bit to 8-bit quantization worth the slight drop in accuracy for real-world sensor data? Is Edge Impulse still the king for quick prototyping, or has a new 'hidden gem' tool popped up on your radar?
I’d love to hear about your latest wins (or even the projects that crashed and burned!). Let’s share some insights and maybe save each other some debugging time.
  • I'm more of a phone than a smaller IoT guy, but from what I understand, yes TFLite Micro & CMSIS-NN are the good solutions. For that memory overhead - just need to quantize / prune / use smaller models.
    How far to quantize? Nothing for it but to test where you lose too much quality. Sometimes the model can't cope and you have to stick to 16, but usually you can at least dynamically quantize to 8-bit. Static quantization will get you better perf if you can go there though. Try Mixed quantization - keep you softmax/sensitive ops in float, and int the rest.  If you can, try 4-bit, we've got some good results there. Have heard of others even going 2-bit, but I've not tried that far.
