How to prepare tflite for vela compiler?
First of all, I'm not sure if it should be posted here.
If there is an error, please forgive me.
I want to try ethus-U NPU. (developer.arm.com/.../The-Vela-compiler
Therefore I need to use the vela compiler (pypi.org/.../)
I use the example of the following website to make a tflite (www.tensorflow.org/.../post_training_integer_quant)
Then use vela compiler to compile tflite, and then see this warning
 Warning: PACK 'sequential/reshape/Reshape/shape' is not supported on the NPU. Placing on CPU instead
  - Input(s) and Output tensors must not be dynamic
   Op has dynamic tensor(s): sequential/reshape/strided_slice2
 Warning: STRIDED_SLICE 'sequential/reshape/strided_slice2' is not supported on the NPU. Placing on CPU instead
I'm not sure what does ''dynamic'' mean for this compiler?
This code comes from part of the example mentioned above:
model = tf.keras.Sequential([
        tf.keras.layers.InputLayer(input_shape=(28, 28)),
        tf.keras.layers.Reshape(target_shape=(28,28,1),input_shape=(28,28,1)),
        tf.keras.layers.Conv2D(filters=12, kernel_size=(3,3),activation='relu'),
        tf.keras.layers.MaxPool2D(pool_size=(2, 2)),
        tf.keras.layers.Flatten(),
        tf.keras.layers.Dense(10)
l
I’m not sure if this is the case for functions like reshpae, or it’s my coding problem.
  • Hi ,
     For some network architectures we don't know at load time, what the necessary sizes will be for all the tensors (input, output and intermediate). For such dynamic tensor size specified to the model specified might be at load time or known based on the size of the inputs etc. This is called dynamic tensor and they are classified as different types.
    Coming back to the issue, in this case it's just a print message where we are checking the tensor size: ethosu/vela/supported_operators.py
    def constraint_tens_no_dynamic(op):
            "Input(s) and Output tensors must not be dynamic"
            valid = True
            extra = []
            tensors = [tens for tens in op.inputs + op.outputs if tens]
            for tens in tensors:
                if (tens.shape == []) and (tens.values is None):
                    valid = False
                    extra.append(tens.name)
            extra = ", ".join(extra)
            return valid, f"Op has dynamic tensor(s): {extra}"
    The warning " Warning: PACK 'sequential/reshape/Reshape/shape'" that you are getting is because you are using float 32 and ops falling back on CPU as U55 only supports int8/int16 weights/activations. I suspect the model is not quantised.
    RESHAPE op is supported by U55 for fallback on NPU. Details - review.mlplatform.org/.../SUPPORTED_OPS.md
    Hope this helps. You can also use support-ml <support-ml@arm.com> for your issues if you are Arm License customer.
  • Thank for you reply!
    I use netron to see this picture
    I found that this place is int32.
    I guess it may be the possibility of quantification failure.
    The same as you suspected.
    Thank you for your answer this time, and I will review the part I did quantify.
  • Hi everyone,
    About a year ago, I started working on mobile machine learning and although I don't claim to be an expert by any means, I wanted to share with you all a technical guide to train a custom model with TensorFlow Lite and then build an Android app that uses that same model. The post includes 2 parts:
    This post is about using the TensorFlow framework to evaluate and train a model for inference on mobile - that includes optimizing and converting it for the TFLite mobile framework.
    In the 2nd post, I go over how to add the model that we've trained to your app - this includes pre and post processing and using the TFLite framework.
    Let me know what you think and I hope this helps you start getting into mobile ML
    www.targetpayandbenefits.com
  • I found that my question is similar to tensorflow/tensorflow#45090 (comment)
    This problem seems to be related to dynamic size in keras.
    So  there is this warning " Input(s) and Output tensors must not be dynamic "
    So you  must  fix the batch size of input layer before tflite conversion
