missing startup file.s when generating the code with STMCubemx
Hallo everyone.
uhh latley i have been have issue when i auto generate a code with cubemx it doesnt load the startp s file for the board as you can see in the text under
Build started: Project: test
*** Using Compiler 'V6.14', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'
Build target 'Target 1'
ArmClang: error: no such file or directory: 'D:/Documents/TEST/RTE/Device/STM32F030R8Tx/STCubeGenerated/MDK-ARM/startup_stm32f030x8.s'
ArmClang: error: no input files
assembling startup_stm32f030x8.s...
".\Objects\test.axf" - 2 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:00
i have a work around it but it still strange why is this happening because a couple a weeks ago it didnt have this issue.
does anybody know how to fix this?
DEVICES:
KEIL 5.3V
STMCUBE: 5.6V
board: STM32F030R8
