Assembly code for reading internal EEPROM of AT89S8252: WMCON DATA 96h ; watchdog and memory control register EEMEN EQU 00001000b ; EEPROM access enable bit EEMWE EQU 00010000b ; EEPROM write enable bit WDTRST EQU 00000010b ; EEPROM RDY/BSY bit orl WMCON, #EEMEN ; enable EEPROM accesses mov dptr, #ADDRESS ; address to read movx a, @dptr ; read EEPROM xrl WMCON, #EEMEN ; disable EEPROM accesses I want to convert this code to a C function like this: unsigned char eepromread(unsigned int address); Address of data byte in EEPROM (content of DPTR register) can be set easily. Please tell me how to convert the following instructions to Keil C. mov dptr, #ADDRESS ; address to read movx a, @dptr ; read EEPROM Suppose that the result is saved to a unsigned char variable.
Please tell me how to convert the following instructions to Keil C. mov dptr, #ADDRESS ; address to read movx a, @dptr ; read EEPROM 1) WHY, if it works, keep it 2) If the storage is in xdata, the compiler has to invoke the DPTR. Erik
unsigned char eepromread ( unsigned int address) { unsigned char retval; WMCON |= EEMEN; retval = XBYTE[address]; WMCON &= ~EEMEN; return (retval); }
