Am using FM v11.12 on Win10 and when I start the model debugger from the GUI - either from the System Canvas or standalone GUI, select more than one target to load as in the following SS, the second instance upon launch is unstable - the debugger window keeps continuously flickering - this suddenly started to occur out of the blue; it was OK initially after installation making me suspicious about some thing else, like a system issue with some windows update and/or some corruption in one of the system files:
SS after attempting to load the above two targets i.e. CPU & the Flash device - the model debugger hangs with partially populated window for the Flash model and has to be forcefully shutdown:
Anyone faced this ? I attempted to remove and re-install teh ARM tools but did not help; also tried building with both VS2017, VS2015 - no difference
Thx !
A quick update - I removed ARM FM tools + 3rd party IP completely, selecting to remove all files changed or not, followed by manually deleting all remnants in the install folder & then installed FM v11.10, a couple of versions prior - and it seems ok, at least now, I do not see the issue.
Not sure what went / was wrong with v11.12 which worked for a few weeks and then went bananas - I'd welcome anyone sharing insights/comments
THX !
Hello CDAMP,
I suspect the uninstall helped to 'clean up' whatever was causing this issue, possibly a pathing issue mixing 11.10 and 11.12 installs (?). Reinstalling 11.12 cleanly should continue to work again.
Thanks Ronan - appreciated!
Will attempt a clean re-install of v11.12 the same way as I did for 11.10 when I get the chance
View all questions in Simulation Models forum
