Site
Search
User
Site
Search
User
Support forums
app crashes when compiled with OTime O3 using RVDS 4.0
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
92 subscribers
Views
Users
0 members are here
AMBA
Bus Architecture
AHB
Options
More actions
Cancel
Related
pradipig pradipig
over 12 years ago
Note: This was originally posted on 1st December 2008 at
http://forums.arm.com
I am using RVDS 4.0 trial version. When I compile my app using OTime O3 compiler flag, the application crashes. But if I specify O2 then it is working properly.
My compiler flags are :
-DRVCT -DDYNAMIC_APP -DBREW --cpu=ARM926EJ-S --apcs=/ropi/interwork/norwpi -c -Otime -O2 --littleend --split_sections -zo
My linker flags are:
--split --reloc --entry AEEMod_Load --first AEEMod_Load --callgraph
please do let me know if i need to specify anything else in the compiler/linker flag options
0
Jacob Bramley
over 12 years ago
There are a a couple of likely explanations:
When you compile with "-O3", the compiler uses multifile compilation by default. Where multifile compilation causes problems, it generally does so at compile time, though it might be worth adding the "-no_multifile" switch to check. If you're compiling one file at a time, this won't make any difference.
As you might expect, "-O3 -Otime" will produce larger code than "-O2 -Otime" as it aggressively optimizes for speed at the cost of code size. Thus, it's possible that your binary image has crossed a page boundary or exceeded some other size limit.
Have a look at the RVCT reference manual to see if the side-effects of your options can cause the problems you are seeing in your specific system. "-Otime" is documented [url="
http://infocenter.arm.com/help/topic/com.arm.doc.dui0348b/CIHCBJIF.html
"]here[/url], and "-O3" is documented [url="
http://infocenter.arm.com/help/topic/com.arm.doc.dui0348b/CIHGFGFB.html
"]here[/url].
I hope that helps,
Jacob
Cancel
Vote up
0
Vote down
Cancel
0
Jacob Bramley
over 12 years ago
In addition, it's also possible that you've done something in your code which isn't guaranteed to do what you think. The C specification is quite vague about a number of things, and turning up the optimization level can expose bugs in which the code makes assumptions about how data will be stored or handled. Finding these bugs can be very difficult.
Cancel
Vote up
0
Vote down
Cancel
0
bsr1100
over 12 years ago
Note: This was originally posted on 5th December 2008 at
I had same issues with RVDS 3.1, my application used to crash in -O3 -Otime optimization settings but worked fine till -O2. After applying the patch for the RVCT available on the ARM site it worked totally fine.
RVDS 4.0 is quite new and I guess it might take some time for them to come up with patches for the same ( If its required at all in the first place ). I dont know if u could fix the problem from Jacob`s suggestion, but this is another perspective to a similar problem.
check out if any patches are available.
Cancel
Vote up
0
Vote down
Cancel
