apb 2.0 continuous transfer
Hi All,
      Now i am focusing on the apb 2.0 specification.
     How to perform a continuous transfer in apb 2.0 . I read some forum , But i did't get a idea.
      If anyone know the continuous transfer in apb 2.0 ,Please share the waveform . It;s easily understand for me.
    For my understanding :
        First clock i am setting setup phase (paddr,pwrite,pwdata,psel) , then the second clock cycle setting the access phase(penable).
        Third clock cycle disable the penable, psel . This is for normal write operation.
        In continuous transfer third clock cycle stable the psel high and disable  the penable for one clock period ?
          or
       third clock cycle psel and penable  stabel high ?
          Which one is the correct.............
Thanks in Advance
Rajaraman R
  • Your first description is correct.
    For a continuous sequence of APB accesses to the same peripheral, PSEL would remain high and PENABLE would be de-asserted for one cycle at the start of each individual APB access to indicate the "setup phase".
    See figure 4-1 in the APB protocol documentation, which shows the APB state diagram. When you are in the "ACCESS" bubble (PSEL=1 and PENABLE=1) and completing an access (PREADY=1), to perform another access immediately you follow the arrow on the right taking you immediately back to the "SETUP" bubble where PSEL=1 and PENABLE=0.
