LPC2138 Program Execution Issue
Hello everybody,
I am using Keil microvision IDE (EVALUATION copy) for my project testing. I am burning hex file through flash magic software using ISP mode.
Initially i wrote simple serial port (uart0) example code.Also added few lines to toggle LED connected to pin P1.24.
Now when i compiled code in Microvision V5 (keil MDK), its serial message showing in my PC hyper terminal. Bit LED (related port pin) state not changed to show blinking.
Hence i copy code & compiled in Microvision Keil 4 IDE, But there nither serial messaging nor led blinking happened.
when i retested same in Keil MDK again serail message shows but not LED, why so ?
I tested all parameters well again & again ( FOSC,CCLK,PCLK  settings, UART0 & port settings). All are correct.
Anybody  has any idea whether my controller is not executing well?
have some found similar issue?
Author:-    Embedded Laboratory
FOSC = 10MHz
CCLK = 60MHz
PCLK = 15MHz
#include <LPC213X.H>
void initClocks(void);
void initGPIO(void);
void toggle_led(void);
void delay_100ms(unsigned char ii);
#define REL_EN       (0x01<<22)   //p0.22
#define LED1          (0x01<<24)   //p1.24
//#define LED2          (0x01<<26)   //p1.26
char String[]="Welcome to LPC!!! \n\r\n";
unsigned int delay;
/**************Function Prototypes************/
void UART0_Init(void);
void UART0_Write(unsigned char value);
void UART0_Write_Text(unsigned char msg[]);
unsigned char UART0_Read(void);
unsigned char msg[] = "Embedded Laboratory\r\n";
unsigned char echo_test[] = "Echo Test\r\n";
int main()
	initClocks();
	initGPIO();
    UART0_Init();
    UART0_Write_Text(msg);
    UART0_Write_Text(echo_test);
    while(1)
		toggle_led();
        UART0_Write(UART0_Read());
/****************Function Definition**********/
	PLLCON = 0x01;   //Enable PLL
	//PLLCFG = 0x24;   //Multiplier and divider setup	//12mhz crystal
	PLLCFG = 0x25;   //Multiplier and divider setup		//10mhz crystal
	PLLFEED = 0xAA;  //Feed sequence
	PLLFEED = 0x55;
		while(!(PLLSTAT & 0x00000400)); //is locked?
	PLLCON = 0x03;   //Connect PLL after PLL is locked
	PLLFEED = 0x55;
//	VPBDIV = 0x01;    // PCLK is same as CCLK i.e.60 MHz
	VPBDIV = 0x00;    // PCLK =15mhz is same as 1/4th of CCLK i.e.60 MHz
/***************UART-0 Functions**************/
    PINSEL0 = 0x00000005;                //P0.0 as TX0 and P0.1 as RX0
    U0LCR = 0x83;                                //Enable access to Divisor Latches
    //and Set 8 bit Character Length with 1 Stop bit and Parity Disabled
    //Access to Divisor Latches is Enabled, in order to write Baud Rate Generator Registers
    //Values to be written in Baud Rate Registers U0DLM and U0LL
    Formula is
    Baud_Rate = PCLK*MulVal / [(16*(256*U0DLM+U0DLL)*(MulVal + DivAddVal))]
    Example:-
    MulVal = 1;
    DivAddVal = 0;
    Baud_Rate = 9600;
    PCLK = 15MHz
    U0DLM = 0;
    Hence,
    U0DLL = 15000000/(9600*16) = 97.65625 = 98
    U0DLL = 98 = 0x62
    U0DLM = 0x00;
    U0DLL = 0x62;                                    //Baud Rate of 9600
    U0LCR = 0x03;                                    //Disable Access to Divisor Latches
		IOCLR1 = LED1;
		//IOCLR1 = LED2;
		delay_100ms(10);
		IOSET1 = LED1;
		//IOSET1 = LED2;
		delay_100ms(10);
//delay of 100 msec
    unsigned i,j;
    i = 648117;
    j = i * ii;
    for(i=0;i<=j;i++)
        ii = 0;
void initGPIO(void)
	PINSEL1 = 0x00000000;
    PINSEL2 = 0x00000000;
    IODIR0 = 0xFFFFFFFC;
    IODIR1 = 0xFFFF0000;
    THRE bit can be extracted by this U0LSR & 0x20
    THRE = 0 means data is present.
    THRE = 1 means register is empty.
    In order to transmit data, we have to wait will the THRE = 1,
    then only we can transmit data.
    while(!(U0LSR&0x20));                        //THRE = 0 stay here
    U0THR = value;
    while(*msg)
        UART0_Write(*msg);
        msg++;
    Receiver Data Ready = U0LSR.0 bit
    RDR bit can be extracted by this U0LSR & 0x01
    RDR = 0 means no Data is Received in U0RBR
    RDR = 1 means that Data is present in U0RBR
    while(!(U0LSR & 0x01));                        //RDR = 0 stay here
    return (U0RBR);
Please guide me.
Regards & thanks,
Kishor.
