Hello. Help is needed in developing an electromagnetic tracking system. I wound coils, made hardware and wrote a program. But the system is not working properly. I need help from a person who has already developed such a system. Thanks in advance.
Not really anything to do with ARM.
Cheak the program properly. if any fault is present in the program then the system will not work. so it is mandatory to write a correct program. secondly, check the hardware part. check the coil, is it okay or not. Use a proper processor according to the system work.
View all questions in Embedded forum
