Hello to everyone,
i would like to know what is the default configuration option of '--enable-checking' for GNU arm compiler 7.3.1.
Thanks in advance,
Best Regards,
Andrea
https://stackoverflow.com/a/3138856
https://stackoverflow.com/a/18600837
Why have you posted this in "Infrastructure Solutions" ?
Why not under "GNU Toolchain" - which seems the more obviously relevant place ?
Please provide feedback at https://community.arm.com/community-help/f/discussions as to how the signposting could be improved ...
Sorry,
I put in Infrastructure Solutions for mistake.
However I'm interested on runtime check option that is not present in the list:
C:\ti\ccs1011\ccs\tools\compiler\gcc-arm-none-eabi-7-2018-q2-update-win32\bin>arm-none-eabi-gcc -Q --help=targetThe following options are target specific: -mabi= aapcs -mabort-on-noreturn [disabled] -mapcs [disabled] -mapcs-frame [disabled] -mapcs-reentrant [disabled] -mapcs-stack-check [disabled] -march= armv2 -marm [enabled] -masm-syntax-unified [disabled] -mbig-endian [disabled] -mcallee-super-interworking [disabled] -mcaller-super-interworking [disabled] -mcmse [disabled] -mcpu= [default] -mfix-cortex-m3-ldrd [disabled] -mflip-thumb [disabled] -mfloat-abi= soft -mfp16-format= none -mfpu= vfp -mhard-float -mlittle-endian [enabled] -mlong-calls [disabled] -mneon-for-64bits [disabled] -mpic-data-is-text-relative [enabled] -mpic-register= -mpoke-function-name [disabled] -mprint-tune-info [disabled] -mpure-code [disabled] -mrestrict-it [disabled] -msched-prolog [enabled] -msingle-pic-base [disabled] -mslow-flash-data [disabled] -msoft-float -mstructure-size-boundary= 8 -mthumb [disabled] -mthumb-interwork [enabled] -mtls-dialect= gnu -mtp= soft -mtpcs-frame [disabled] -mtpcs-leaf-frame [disabled] -mtune= [default] -munaligned-access [disabled] -mvectorize-with-neon-double [disabled] -mvectorize-with-neon-quad [enabled] -mword-relocations [disabled]
Pisc86 said:I put in Infrastructure Solutions for mistake
How? it's nowhere near the correct forum.
Again, your feedback in improving the signposting would be appreciated.
Have you also tried --target-help and -Q -v as mentioned on Stack Overflow ?
Pisc86 said:C:\ti\ccs1011\ccs\tools\
As you're using TI tools, have you asked them?
Pisc86 said:i would like to know what is the default
You could always just set it explicitly to whatever you want ...
Yes I've tried arm-none-eabi-gcc -Q -v --help=target.
I'm not sure that the runtime check is activated (even if '-enable-checking=runtime' is added), infact no error have been raised during compiling if it is inserted typo in the command such as ''-enable-checking=agaggaga' or ''-enable-checkingdffg=agaggaga".
I don't choose the correct forum because I click on '+ New' without seeing below the forum selected by default.
It would be very useful to give the possibility to choose the forum after clicking '+ New' button.
BR
Pisc86 said:I don't choose the correct forum because I click on '+ New' without seeing below the forum selected by default. It would be very useful to give the possibility to choose the forum after clicking '+ New' button.
Again, feedback needs to be here: https://community.arm.com/community-help/f/discussions
EDIT
Here: https://community.arm.com/community-help/f/discussions/49419/the-reason-why-so-many-first-questions-end-up-in-infrastructure-solutions
