Sht11 interfacing with lpc1758
Please anyone worked on sht11 interfacing with lpc1758. Please help me I m getting communication error. The library I used for sht11 is working properly for
  • Why have you posted this under 'Infrastructure Solutions' ?
    Remember that the SHT11 neither knows nor cares what microcontroller you use - all it sees is the signals on its interface lines.
    If you supply the required signals to it - as defined in its documentation -  it will work.
    have you used an oscilloscope or logic analyser to verify the signals?
    So fix that error!
    for what ?
