How to convert a BIN into an ELF object image with armlink?
I'm wondering how I could use 'armlink' to combine or merge a binary image into another image. With the ARM GNU tools, I can do the following:
1) Perform a partial linking (switch '-r') of as input file in binary format (switch '-b binary'). This will generate an ELF object file defined by switch '-o':
% arm-linux-gnueabihf-ld -r -o foo.o -b binary foo.bin
2) Then, one can link the resulting object file to generate a final binary. The "-T" switch points to the link script and "-o" defines the resulting output.
% arm-linux-gnueabihf-ld  -T foo.ld foo.o -o output.bin
The linker script may look something like this:
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm")
SECTIONS
    . = 0x0;
    .text : {*(.text)
#if defined(CONFIG_LOOPSELF_PHYS_ADDR)
        __foo_start = .;
        foo.o
        . = ALIGN(4);
        __foo_end = .;
#endif
How could I do something similar with the ARM tool chain? I understand that 'armlink' allows for partial linking (--partial switch). But I could not find any 'armlink' switch for binary inputs. Am I missing something?
Also, I found this note on "How to use armlik to combine two images":
https://community.arm.com/community-help/f/discussions/2043/how-to-use-armlik-to-combine-two-images
It describes a different method to possibly achieve the same goal. It involves writing some assembler source that includes the binary in a different section as also defined in the scatter file:
area my_code, code
   incbin my_code.bin
   area other_code, code
   incbin other_code.bin
end
Is that the only way I can achieve this?
