I'd like to know if generate Performance Advisor with system wide profiling is available or not.
I've already confirmed that I could run Streamline with system-wide profiling setting on my Android development device environment.
In this case, just call below command, then start capture on Streamline tool.
./data/local/tmp/gatord --system-wide=yes &
Then, I used "Streamline-cli.exe" command in order to generate Performance Advisor html.
However, I faced below error.
ERROR: Cannot find any frames. Please refer to the user guide for methods of providing frame data to Performance Advisor.ERROR: Process name () does not match any of the processes in the capture. Use the -p option to specify the process to use. Processes in the capture:
I guess it means that I need to run "streamline_me.py" command in advance.
But, when call "streamline_me.py" command, it require to select debuggable application.
If I'm not mistaken, there are no system-wide profiling related command option on "streamline_me.py".
It means Performance Advisor only support application profiling ?
I cannot find explanation how to enable system-wide profiling setting on Performance Advisor procedure.
Please help to explain the procedure if it's available...
Thank you
Hiroki Katano said:It means Performance Advisor only support application profiling ?
Yes. It's a frame-based profiler, which only really makes sense in the context of a single application.
HTH,Pete
Hi there, thanks for asking a question. It looks like you have a suggested answer however others may have a similar question so please may you let me know what forum is best so that I can moved your question to it? Support forums Thanks.
Thank you for replying.
Noted that Performance Advisor is unavailable on System profiling.
https://developer.arm.com/documentation/101816/0903/Analyze-your-capture/Viewing-application-activity/Mali-Timeline-mode?lang=en
BTW, How about "Mali Timeline" ?
I couldn't see Mali Timeline result on Streamline with System profiling.
On the other hand, I could see it with Application profiling setting.
Best Regards
