Mobile, Graphics, and Gaming blog ARM Mali-V500 Overview
  • Video
  • Mali
  • mali-v500
Ellie Stone
Ellie Stone
August 13, 2013
2 minute read time.
The ARM® Mali™-V500 offers advanced video technology combined with power-efficiency and one of the smallest chip sizes in the market to creators of mass-market mobile devices. Designed to scale from 1080p60 on a single core to 4k120 on the full eight cores, all Mali-V500 variations will offer stunning HD visual and experiential quality to end users. The ARM Mali-V500 is the initial offering in the innovative Mali Video roadmap and offers multi-standard codec support.
Why Mali-V500?
multi-stream video call via Skype
Building on the strong momentum and expertise of ARM Mali’s graphics solutions, the Mali-V500 offers a scalable, secure solution to the video processor
market capable of 4k resolution at 120fps on eight cores; thanks to this “trick-play,” video edit and slow motion capture in HD is consequently possible. Even with a single core, the Mali-V500 is capable of bringing 1080p60 performance to mass-market smartphones, accordingly meeting growing consumer expectations and changing video consumption patterns. The design is capable of managing multiple, simultaneous encode and decode HD streams and through this can support multi-party video conferencing and advanced user interfacing.
The Mali-V500 incorporates a novel lossless frame compression technique, ARM Frame Buffer Compression (AFBC). By coupling AFBC in the Mali-V500 with AFBC in either the display controller or Mali GPU a bandwidth saving of over 50% is achievable. This delivers a considerable system-wide power reduction, potentially allowing the use of lower cost DRR memory.
At all times ARM takes a system-wide approach to security starting with the deepest levels of hardware and software. In accordance with these values, the Mali-V500 was architected with support for TrustZone® enabling hardware-backed content security from download to display.  As high value movie and TV content is consumed across a wider range of devices, creators and distributors of this content are looking for greater protection of their investments and all ARM video solutions will meet these demands.
For use cases such as gaming on Wi-Fi display it is important to users that latency from mobile device to display is as low as possible, at least <100ms in order to maintain an engaging experience. The Mali-V500 boasts latency of <10ms at 1080p30 for both encode and decode making gaming on Wi-Fi display a compelling experience.
Whether we are talking about graphics or video processing, visual quality is extremely important and Mali-V500 includes high bus latency tolerance whereby video processing can continue for over 5000 cycles without external memory access. This feature ensures that consumers will not see jerky playback due to dropped frames when other processes are happening on the device.
Specifications
FeaturesValueDescription
API SupportFor encode: H.264, VP8 For decode: H.264, H.263, MPEG4, MPEG2, VC-1/WMV, Real, VP8Driver and video streaming infrastructure based on OpenMAX™ which runs on the host CPU
Bus InterfaceAMBA3 AXI or AMBA 4 ACE Lite Compatible with a wide range of bus interconnect and peripheral IP
Memory SystemMMUBuilt-in Memory Management Unit (MMU) to support virtual memory
Frequency600MHz A single core clocked at 600MHz is capable of 1080p60 decoding or encoding
Performance1080p60 to 4k120* [*2160p]Scalable from one to eight cores with multiple performance points
  • wangyong
    wangyong over 11 years ago
    Hi Ellie,
    Thanks a lot!
    Best.
  • Ellie Stone
    Ellie Stone over 11 years ago
    Hi wangyong,
    Thanks for the question! I checked with the Mali-V500 product manager for you and the answer is that we are able to utilise the MMU built into the Mali-V500 processor which can be programmed to a secure mode from a Trusted Execution Environment. This allows us to minimize fragmentation of protected memory and deliver a TrustZone enabled hardware solution "out of the box" to partners.
    Best,
    Ellie
  • wangyong
    Would you explain how Mali-V500 support TrustZong? There is little information about this in ARM official website.
    Vidya Praveen
    Vidya Praveen
    • September 19, 2025
    Jai Schrem
    Jai Schrem
    • August 27, 2025
    Liam O'Neil
    Liam O'Neil
    • August 12, 2025
