Architectures and Processors blog TrustZone and FIDO: Protecting your privacy and identity
  • tee
  • fido
  • TrustZone
Rob Coombs
Rob Coombs
May 22, 2015
1 minute read time.
Identity thieves are getting quite sophisticated when it comes to stealing your username and password.   We might be wary of an unsolicited email containing a link but what if it came from a friend's email account?  This happened to my wife recently - her friend's PC had been taken over and was sending believable emails to all her contacts (the PC was later encrypted by the hackers and held to ransom for  bitcoins).  If you clicked the link up would pop a window purporting to be from Google asking you to login with your username and password... .  Then there is the issue of having to remember too many long and complex passwords for the different web services we all use.     I think most of us would agree that passwords aren't safe and they are painful to use.
Fortunately the combination of a new authentication protocol called FIDO (Fast ID Online) and biometrics is changing the landscape rapidly.   The FIDO Alliance is a group of approximately 200 companies working together to create a new protocol that provides simpler, stronger authentication.   It can work with many different types of authenticator such as fingerprint sensor, iris scanner or trusted PIN entry.  The device (not the remote sever) creates a public/private key pair for each combination of user/device/relying party during registration and provides the public key to the relying party.   The sensitive parts of the algorithm e.g. crypto, matching, key stores need to be protected from scalable attacks.   Fortunately ARM based applications processors usually implement a TrustZone based Trusted Execution Environment consisting of isolation hardware, authenticated trusted boot and a small Trusted OS.   The TEE is being standardised by GlobalPlatform who are working on a security certification scheme so that it will soon be possible for platforms to be tested by 3rd party labs.  The attached white paper looks at how the TrustZone based TEE is being used with FIDO based systems to protect assets and accelerate the revolution to a world without passwords.
TrustZone and FIDO white paper final.pdf
  • wangyong
    wangyong over 10 years ago
    The link address can be accessed now, thanks.
  • Alban Rampon
    Alban Rampon over 10 years ago
    Hi WangYong, would you mind trying again now?
  • Alban Rampon
    I have the same behaviour. It looks like the text is coloured and underlined but doesn't actually include any link.
    I will work with Rob to update it.
    Thanks for flagging it up WangYong!
  • wangyong
    I also can open the attachment as PDF. The link address in the PDF, such as "GlobalPlatform" in "The TEE is standardized by GlobalPlatform who have created " from the PDF, can't be open.
  • Jens Bauer
    Jens Bauer over 10 years ago
    wangyong wrote:
    The website links in this paper such as "online" with an underline can't be open, do you also find this problem?
    I'm able to open the attachment both as PDF and in the flash viewer on my PowerMac G5 with Safari 5.0.6. Which system/browser are you using ?
    Chris Walsh
    Chris Walsh
    • October 3, 2025
    Martin Weidmann
    Martin Weidmann
    • October 2, 2025
    Wathsala Vithanage
    Wathsala Vithanage
    • September 15, 2025
