Architectures and Processors blog Arm releases Server Architectural Compliance Suite v1.0
  • Architecture
  • Server Base Boot Requirements (SBBR)
  • server
Dong Wei
Dong Wei
July 25, 2017
1 minute read time.
Arm is pleased to announce the v1.0 release of the Arm Server Architectural Compliance Suite (ACS).
Arm Server Base System Architecture (SBSA) and Server Base Boot Requirements (SBBR) specifications require a minimum set of hardware and firmware implementations that ensure operating systems (OS) and platforms interoperate. The latest versions are SBSA v3.1 and SBBR v1.0 and they are available at developer.Arm.com
The ACS is split across two repos:
  • SBSA-ACS on Github (just SBSA tests)
  • Arm Enterprise ACS on Github (umbrella project that collects SBSA and SBBR tests and builds all the relevant images to allow for execution)
These tests are provided as open source via the Apache v2 License. Note, ACS is based on the UEFI Self Compliance Test (SCT), which is not currently open source due to historical reasons. Arm is working with the UEFI Forum to find a solution.
Ultimately, we want to reach the point where the passing of the ACS would provide significant confidence that Arm servers would just work out of the box with the operating environment of their choosing.
SBSA/SBBR Specifications set the foundation for the interoperability between the various operating environments (e.g., Windows, Linux, hypervisors) and the platforms with hardware from many different silicon providers. The ACS is provided to assist the OEMs and ODMs in validating the conformance to these specifications.
Sign up for updates on Server ACS
Top Comments
  • Jerome Decamps - 杜尚杰
    Jerome Decamps - 杜尚杰 over 8 years ago +1
    That's a really good thing :D Hope it will be used soon by the most mainboard makers !
    • Up +1 Down
    Chris Walsh
    Chris Walsh
    • October 3, 2025
    Martin Weidmann
    Martin Weidmann
    • October 2, 2025
    Wathsala Vithanage
    Wathsala Vithanage
    • September 15, 2025
