AI blog Imagimob: The Fastest Path from Data Collection to Embedded AI Application
  • Microcontroller (MCU)
  • Embedded
  • Edge Computing
Mary Bennion
Mary Bennion
October 19, 2020
12 minute read time.
***All content in this blog written by Johan Malm, Ph.D. Johan is a specialist in numerical analysis and algorithm development. He works as a machine learning developer at Imagimob***
We live in a world of data. Virtually everyone talks about data and the potential value we can extract from it. Massive amounts of raw data are complex and hard for us to interpret and, over the past few years, machine learning techniques have made it possible to better understand this data and leverage it to our benefit. So far, most of the value has been realized by online businesses, but now the value is also starting to spread to the physical world where the data is generated by sensors. For many, however, the path from sensor data to an embedded AI model seems almost insurmountable.
Writing embedded software is notoriously time-consuming, and is known to take at least 10-20 times longer than desktop software development [1]. It does not have to be that way. Here, we will walk you through a real AI project—from data collection to embedded application—using our efficient, time-saving method.
Machine Learning on the Edge
Today, the vast majority of software for processing and interpreting sensor data is based on traditional methods: transformation, filtering, statistical analysis, and so on. These methods are designed by a human who, referencing their personal domain knowledge, is looking for some kind of “fingerprint” in the data. Quite often, this fingerprint is a complex combination of events in the data, and machine learning is needed to successfully resolve the problem.
To be able to process sensor data in real-time, the machine learning model needs to run locally on the chip, close to the sensor itself—usually called “the edge.” Here, we explain how a machine learning application can be created, from the initial data collection phase to the final embedded application. As an example, we look at a project we at Imagimob carried out together with the radar manufacturer Acconeer.
Embedded AI project: Gesture Recognition
Acconeer produces the world's smallest and most energy efficient radar system
(Left) Acconeer produces the world's smallest and most energy efficient radar system.
In 2019, Imagimob teamed up with Acconeer to create an embedded application with gesture recognition. Both companies focus on providing solutions for small battery-powered devices, with extreme requirements on energy efficiency, processing capacity, and BOM cost. Our target hardware contains an MCU based on the Arm Cortex-M0 – M4 architecture, which provides the most energy-efficient platforms on the market. For us at Imagimob, edge computing has almost become synonymous with advanced computing on the smallest Arm Cortex M-series MCUs. It is important to be able to run our applications on the lower end of Arm Cortex M-series MCUs since it signals to the world that we are targeting the smallest devices on the planet. And that is where we want to be from a market perspective.
Acconeer produces the world’s smallest and most energy-efficient radar system. The data contains a lot of information, and for advanced use cases, such as gesture control, complex interpretation is needed. These cases benefit greatly from having machine learning software running on top of the data output stream. The Imagimob-Acconeer collaboration is, therefore, a good match when it comes to the creation of radically new and creative embedded applications.
The goal for our project with Acconeer was to create an embedded application that could classify five different hand gestures in real-time using radar data (including one gesture used to wake up the application). With its small size, the radar could be placed inside a pair of earphones, and the gestures would function as virtual buttons to steer the functionality, which is usually programmed into physical buttons. The end product for the project was determined to be a C library running on an Arm Cortex-M4 architecture, which was shown as a robust live demo at CES in Las Vegas in January 2020. For the demo, we used on-ear headphones. However, our long-term product goal is to use this technology in in-ear headphones. We believe that gesture detection especially makes a difference in the usability of in-ear headphones, due to their restricted amount of area which makes the placement of physical buttons difficult.
From Data Collection to Embedded C Library
At its core, (supervised) machine learning is about finding a function (f) that maps some input data (x) to some output data (y), according to y = f(x). The function, or “model,” is found by processing many different input/output pairs (x, y) and “learning” their relationship. If y is a continuous value, the problem is said to be a regression problem. But if y takes on discrete values, then it is considered a classification problem. The first step in a machine learning project is therefore to collect these data pairs. Model building is the second step. And the last step for embedded projects is to deploy the model on a target platform. Below, we go through these steps using the gesture recognition project as a guiding example.
The first step in a machine learning project is to collect data pairs. Model building is the second step, and the last step for embedded projects is to deploy the model on a target platform.
1. Data collection
(Left) We built a rough test rig for initial data collection which consisted of the radar sensor mounted on the development board and placed on a pair of headphones.
On the surface, data collection may not seem like a difficult task. But this step is usually underestimated and, in our experience, this is where much of the time is spent. The first thing to consider is how to physically get the data out from the sensor. Many sensors come with a development board from which data can be extracted, often with some kind of cable connection to a PC. For the gesture recognition project, we built a rough test rig for the initial data collection consisting of the radar sensor mounted on the development board and placed on a pair of headphones, as shown in the following image. In this case, we used the Acconeer XM112 radar sensor and the XB112 breakout board.
The next thing to consider is how the data can be efficiently labeled. In other words, you need to figure out how to mark the appropriate “y” for each “x.” This may seem trivial, but it is crucial when it comes to minimizing the amount of manual work this step will require. Given the large amount of data, if you do not get this right, it becomes a very time-consuming task. For sensor time-series data, it is usually impossible to label the data just by looking at it, which may otherwise be possible with, for example, image data.
One way to aid the labeling process is by having a video recording attached to the data. Imagimob Capture is an Android app that attaches a time-synched video recording to each sensor data stream. Labeling can be done either directly in the app or later on in the desktop app Imagimob Studio. In the case of our radar gesture recognition project, the data flow looked like the following:
 The flow of data in the radar gesture recognition project.
Here, the data is sent from the sensor, with the USB serial port, to a PC. On the PC, a server runs and sends the data to Imagimob Capture on a mobile phone, while the gesture is being video recorded. The labeled data, together with its video recording, is then sent back to the PC, or to cloud storage if data is being collected remotely. From the storage, the data can be downloaded to Imagimob Studio, when it is time for the modeling phase.
We defined the following set of gestures (“Cover sensor” is only used to wake up the application) and recorded data from roughly seven different people.
Data was recorded from seven different people for the above set of gestures.
An example of the data collection process is shown in the following image. The gesture recognition model is limited to the specific gestures, but can easily be retrained with other gestures.
An example of the gesture data collection process.
2. Modeling
Once the data is in place and labeled, it is time to build a machine learning model. Often, people start building a model only to soon realize that they need to adjust some of the labels. What do you do? It is cumbersome to manually go in and edit text files and update the data, something we would all like to avoid as much as possible. Rather, a graphical tool is desirable. Imagimob Studio loads the data together with the video recording and lets users drag and trim the labels graphically. An example, featuring one of the recorded gestures, is shown in the following image. The video is visible together with the data in green. At the bottom, the labels in blue are shown and we can see that they are tightly placed around the gesture (the nonzero data).
Imagimob Studio loads data together with the video recording and lets the user drag and trim the labels graphically. This is an example of one of the recorded gestures.
If the data is already pre-labeled in Imagimob Capture, it is a relatively small task to go through the files and make sure the data is correct and that the labels are in place. Without correctly labeled data, it is difficult to find a good model. Finding a good model with high accuracy usually involves many iterations and experiments. The first thing to decide is what machine learning technique to use, for example, random forests, support vector machines or artificial neural networks, among others. In the past few years, deep learning has gained popularity due to the impressive learning capabilities with raw data. One of the main attractions of deep learning is that it excludes the need of manually finding features which is required in more traditional machine learning approaches. It has both the potential to increase accuracy and eliminate a lot of the manual work. However, there are still many so-called hyperparameters left to be chosen, for example, the architecture of the network, so-called learning rate, and many others.
In Imagimob Studio, users are walked through the process of building a deep neural network. The user defines how many different types of hyperparameters to try out, then the program automatically searches through all the combinations and saves the best model.
In Imagimob Studio, users are guided through the process of building a deep neural network. The user defines how many different types of hyperparameters to try out, then the program automatically searches through all the combinations and saves the best model.
Once you are happy with the robustness of the model, it is time for the final step in the process: Exporting the model to C code and building a library for the embedded hardware.
3. Deployment
When going from software development in high-level languages in a PC environment to lower-level programming on microcontrollers (MCUs), there is a sharp increase of complexity. Development time increases in factors of 10-20 are not uncommon [1]. The hurdles can include, for example, harder memory and processing restrictions, longer debugging cycles, and nastier types of bugs that are harder to find.
In Imagimob Studio, a trained model in the form of a .h5 file is easily translated to C code for a specific hardware type, shown on the “Edge” tab.
In Imagimob Studio, a trained model in the form of a .h5 file (a common format used to export model weights and architectures from Tensorflow, Keras, and other deep learning frameworks) can be easily translated to C code for a specific hardware type, as shown on the “Edge” tab in the previous image.
The C code is then compiled and flashed to the hardware. We usually build a library that can be integrated into a C application. To the right, you can see the embedded version of the live demo. It has a battery driven Acconeer IoT module XM122 with a bluetooth connection. The AI application runs on the XM122 module, which includes an nRF52840 SoC from Nordic Semiconductor which is based on an Arm Cortex M4 MCU.
The embedded version of the live demo.
Here, you can take a look at the final demo:
Imagimob Gesture Detection Library Specifications
At its core, the Imagimob Gesture Detection Library is composed of an artificial neural network targeted to time series data. It is specifically designed with a small memory footprint in mind. The library is written in C and compiled in a static library, which is then compiled together with the main Acconeer C application.
· The Gesture detection library uses radar data from the Acconeer XM122 IoT Module as input
· The memory footprint of the gesture library is approximately 80 kB RAM
· The library runs on a 32-bit 64 MHz Arm Cortex M4 MCU with 1 MB Flash and 256 kB RAM
· The library processes roughly 30 kB of data per second
· The execution time of the AI model is roughly 70 ms which means that it predicts a gesture at approximately 14.3 Hz
The Next Step: Gesture-controlled In-ear Headphones
In June 2020, a consortium consisting of Imagimob, Acconeer, and Flexworks received a grant worth $450,000 from Swedish Vinnova to take the next step in building gesturhe-controlled in-ear headphones. Acconeer will cover the sensing part, Flexworks will be responsible for hardware and mechanics, and we at Imagimob will develop the gesture detection application. In this project, not only will we build the first gesture-controlled in-ear headphones, but we will also work towards a hardware accelerated system for the machine learning code on the MCU. We will continue to use the Arm Cortex M series and benefit from the advanced solutions provided by Arm.
Sign up for a free trial
Johan Malm, Ph.D. is a specialist in numerical analysis and algorithm development. He works as a machine learning developer at Imagimob.
References
[1] McConnell, Steve, Software Estimation, Demystifying the Black Art, Microsoft Press, 2006
AI blog
    Hamza Arslan
    Hamza Arslan
    • September 22, 2025
    Lizzie Salter
    Lizzie Salter
    • August 15, 2025
  • Bringing Generative AI to the masses with ExecuTorch and KleidiAI
    Gian Marco Iodice
    Gian Marco Iodice
    With the recent Arm SME2 announcement, the role of Arm KleidiAI is increasingly clear as Arm’s AI accelerator layer powering the next wave of AI.
    • August 13, 2025
