Q : How do I get started developing software for Arm-based laptops and desktops?
A : You can start here with this learning path that introduces the Arm architecture for desktop/laptop development, helps you choose hardware (e.g., Windows, ChromeOS, or Linux on Arm), and guides setup of your dev environment learn. By the end, you'll know where Arm is used and how to start coding on devices like the ThinkPad X13s or Pinebook Pro.
Q : How can I build or migrate native Windows applications on Windows‑on‑Arm with maximum performance?
A : We have several guides to help with this:
If you need help with anything else, please ask in this forum and an Arm Expert will be there to help you right away!
