I've read and reread the Phillips manual and still have a problem with a fast interrupt routine. I want timer 0 to trigger a fast interrupt. In the timer 0 service routine, I just want to do an A/D conversion into an array. I can't seem to get it to work. I'd appreciate it if anyone could tell me what I am doing wrong. The interrupt service routine and the routine which set up timer 0 are shown below. In the rest of the program, I just enable the timer 0 interrupt to start it off and disable it when the array is filled Thanks in advance, Jim void fiqint(void) __fiq // // Timer 0 interrupt routine // { unsigned int val; AD0CR |= 0x01200000; // start A/D conversion do val = AD0DR; while ((val & 0x80000000) == 0); AD0CR &= ~0x01000000; data[index++] = val; T0IR = 0x08; // clear the flag VICVectAddr = 0; } void timer0_init(void) // sets up timer 0 to interrupt every sample time using the FIQ interrupt { // float sample_freq; T0MR0 = (VPB_CLOCK / (SAMPLES_PER_CYCLE * expected_freq)) - 1; // sample_freq = ((double) VPB_CLOCK) / ((double) (SAMPLES_PER_CYCLE * (T0MR0) + 1)); // printf("T0MR0 is %d\n\r", T0MR0); // printf("Sample frequency is %g\n\r", sample_freq); T0MCR = 3; // timer 0 triggers on match and resets itself T0TCR = 1; // start the clock VICIntSelect = (1 << 4); // Timer0 made to be the FIQ }
In the following thread: http://www.keil.com/forum/docs/thread5969.asp there is a description about a timer in fiq mode that works. Dietmar
