Is there any way to enforce padding between subroutines using the scatter file?
Hi!
I am using an ARM Cortex-M23 microcontroller. I wish to pad every subroutine with certain number of bytes. Using the ALIGNALL attribute on an execution region I am able to achieve some success but I cannot control the number of bytes. Further, the ALIGNALL attribute does not seem to work on veneer code. While I can place the veneer code in a separate execution region, I cannot align the veneer code as I please. Is there any way to achieve what I am trying to do?
Thank you
  • Can you post your scatter file. It may help to help you.
    Ah, and maybe tell which tool chain you are talking about.
  • Hello
    The contents of my simple scatter file  are provided here:
    LR_ROM 0x10040000 0x10000 {
      ER_ROM_CODE +0 ALIGNALL 32{
    	*.o (+RO)
    LR_ROM2 0x10050000 {
      ER_ROM_CODE2 +0 ALIGNALL 32{
    	*(Veneer$$Code)
    ;  ER_ROM_UNUSED +0 FILL 0xFFFFFFFF (0x40000 - ImageLength(ER_ROM_CODE)) {
      RW_IRAM_THREAD_CODE 0x30008000 0xE800 {
    	*(+RW, +ZI)
    I am using the MDK-ARM toolchain. The toolchain version is 5.30.0.0. Please let me know if you need any other information.
    Thank you
  • Guessing: DS 5: ALIGNALL works fine for me.
  • Do you mean the DS-5 toolchain?
  • So you are telling, section ER_ROM_CODE2 does not align?
    I tried a simple example, but hat no veneers inside, so I could not test this, but using some other custom section names alignment did work correctly.
    DS5 = DS-5, yes. But the compiler/linker is the same as in Keil.
  • Yes. ER_ROM_CODE2 does not align. For example, this is an excerpt from the NonSecure.txt file generated by the linker.
    ** Section #2 'ER_ROM_CODE2' (SHT_PROGBITS) [SHF_ALLOC + SHF_EXECINSTR + SHF_ARM_PURECODE]
        Size   : 120 bytes (alignment 32)
        Address: 0x10050000
        $t
        $Ven$TT$L$$SecureContext_SaveContext
            0x10050000:    b403        ..      PUSH     {r0,r1}
            0x10050002:    2000        .       MOVS     r0,#0
            0x10050004:    0200        ..      LSLS     r0,r0,#8
            0x10050006:    3000        .0      ADDS     r0,#0
            0x10050008:    0200        ..      LSLS     r0,r0,#8
            0x1005000a:    300c        .0      ADDS     r0,r0,#0xc
            0x1005000c:    0200        ..      LSLS     r0,r0,#8
            0x1005000e:    30a9        .0      ADDS     r0,r0,#0xa9
            0x10050010:    9001        ..      STR      r0,[sp,#4]
            0x10050012:    bd01        ..      POP      {r0,pc}
        $Ven$TT$L$$SecureContext_LoadContext
            0x10050014:    b403        ..      PUSH     {r0,r1}
            0x10050016:    2000        .       MOVS     r0,#0
            0x10050018:    0200        ..      LSLS     r0,r0,#8
            0x1005001a:    3000        .0      ADDS     r0,#0
            0x1005001c:    0200        ..      LSLS     r0,r0,#8
            0x1005001e:    300c        .0      ADDS     r0,r0,#0xc
            0x10050020:    0200        ..      LSLS     r0,r0,#8
            0x10050022:    30a1        .0      ADDS     r0,r0,#0xa1
            0x10050024:    9001        ..      STR      r0,[sp,#4]
            0x10050026:    bd01        ..      POP      {r0,pc}
        $Ven$TT$L$$SecureContext_AllocateContext
            0x10050028:    b403        ..      PUSH     {r0,r1}
            0x1005002a:    2000        .       MOVS     r0,#0
            0x1005002c:    0200        ..      LSLS     r0,r0,#8
            0x1005002e:    3000        .0      ADDS     r0,#0
            0x10050030:    0200        ..      LSLS     r0,r0,#8
            0x10050032:    300c        .0      ADDS     r0,r0,#0xc
            0x10050034:    0200        ..      LSLS     r0,r0,#8
            0x10050036:    3089        .0      ADDS     r0,r0,#0x89
            0x10050038:    9001        ..      STR      r0,[sp,#4]
            0x1005003a:    bd01        ..      POP      {r0,pc}
        $Ven$TT$L$$SecureContext_FreeContext
            0x1005003c:    b403        ..      PUSH     {r0,r1}
            0x1005003e:    2000        .       MOVS     r0,#0
            0x10050040:    0200        ..      LSLS     r0,r0,#8
            0x10050042:    3000        .0      ADDS     r0,#0
            0x10050044:    0200        ..      LSLS     r0,r0,#8
            0x10050046:    300c        .0      ADDS     r0,r0,#0xc
            0x10050048:    0200        ..      LSLS     r0,r0,#8
            0x1005004a:    3091        .0      ADDS     r0,r0,#0x91
            0x1005004c:    9001        ..      STR      r0,[sp,#4]
            0x1005004e:    bd01        ..      POP      {r0,pc}
    Any ideas why this happens? Please let me know.
  • No idea. But Keil should know. What does Keil-Support say?
  • Oh! I haven't asked keil support yet. I'll do that. Thank you for your help!
