SoC Design and Simulation blog Address Space Layout Randomization
  • benchmarking
  • Linux
Jason Andrews
Jason Andrews
October 24, 2015
System optimization involves running Linux applications and understanding the impact on the hardware and other software in a system. It would be great if system optimization could be done by running benchmarks one time and gathering all needed information to fully understand the system, but anybody who has ever done it knows it takes a numerous runs to understand system behavior and a fair amount of experimentation to identify corner cases and stress points.
Running any benchmark should be:
  • Repeatable for the person running it
  • Reproducible by others who want to run it
  • Reporting relevant data to be able to make decisions and improvements
Determinism one of the challenges that must be understood in order to make reliable observations and guarantee system improvements have the intended impact. For this reason, it’s important to create an environment which is as repeatable as possible. Sometimes this is easy and sometimes it’s more difficult.
Traditionally, some areas of system behavior are not deterministic. For example, networking traffic of a system connected to a network is hard to predict and control if there are uncontroled machines connected to the network. Furthermore, even in a very controlled environment the detailed timing of the individual networking packets will always have some timing variance related to when they arrive at the system under analysis.
Another source of nondeterministic behavior could be something as simple as entering Linux commands at the command prompt. The timing of how fast a user is typing will vary from person to person and from run to run when multiple test runs are required to compare performance. A solution for this could be an automated script which automatically launches a benchmark upon Linux boot so there is no human input needed.
Understanding the variables which can be controlled and countering any variables which cannot be controlled is required to obtain consistent results. Sometimes new things occur which were not expected. Recently, I was made aware of a new source of non-determinism, ASLR.
Address Space Layout Randomization (ASLR) has nothing to do with system I/O, but the internals of the Linux kernel itself. ASLR is a security feature which randomizes where various parts of a Linux application are loaded into memory. One of the things it can do is to change the load address of the C library. When ASLR is enabled the C library will be loaded into a different address of memory each time the program is run. This is great for security, but is a hinderance for somebody trying to perform system analysis by keeping track of the executed instructions for the purpose of making performance improvements.
The good news is ASLR can be disabled in Linux during benchmarking activities so that programs will generate the same address traces.
A simple command can be used to disable ASLR.
$ echo 0 > /proc/sys/kernel/randomize_va_space
The default value is 2. The Linux documentation on sysctl is a good place to find information is the randomize_va_space:
This option can be used to select the type of process address space randomization that is used in the system, for architectures that support this feature.
0 - Turn the process address space randomization off. This is the default for architectures that do not support this feature anyways, and kernels that are booted with the "norandmaps" parameter.
1 - Make the addresses of mmap base, stack and VDSO page randomized. This, among other things, implies that shared libraries will be loaded to random addresses.  Also for PIE-linked binaries, the location of code start is randomized. This is the default if the CONFIG_COMPAT_BRK option is enabled.
2 - Additionally enable heap randomization. This is the default if CONFIG_COMPAT_BRK is disabled.
There is a file /proc/[pid]/maps for each process which has the address ranges where the .so files are loaded.
Launching a program and printing the maps file shows the addresses where the libraries are loaded.
For example, if the benchmark being run is sysbench run it like this:
$ sysbench & cat /proc/`echo $!`/maps
Without setting randomize_va_space to 0 different addresses will be printed each time the benchmark is run, but after setting randomize_va_space to 0 the same addresses is used from run to run.
Below is example output from the maps file.
If you ever find that your benchmarking activity starts driving you crazy because the programs you are tracing keep moving around in memory it might be worth looking into ASLR and turning it off!
    Vincent Yang
    Vincent Yang
    • June 5, 2024
  • Introduction to AMBA Viz
    Tony Nip
    Tony Nip
    • May 31, 2024
  • Arm Virtual Platform co-simulation solution accelerates SoC verification
    Daniel Owens
    Daniel Owens
    Avery Design Systems’ co-simulation design verification solution that integrates SystemC-based Arm virtual platforms with a SystemVerilog environment.
    • December 6, 2022
