    • Arm Research
    • Mobile blog
    • Smart Homes
    • Works on Arm blog
    • Open a support case
Internet of Things (IoT) blog Making automation work for you: Managing 1 trillion connections
  • Pelion IoT Platform
  • Internet of Things (IoT)
Niall Strachan
Niall Strachan
November 11, 2019
The basic premise of IoT is easily understood. Devices are deployed and connected for a huge range of use cases. These include; gathering business-critical data, managing access to rooms, tracking goods, monitoring people’s movement, controlling HVAC, and light systems. The possibilities are limited only by your imagination (and technology).
The massive scale at which these devices are coming online is more difficult to grasp. Try to picture the sheer number of connected “things”. From the tiniest sensors to the most feature-rich consumer device. Arm is predicting 1 trillion things will be connected by 2035.
What does that mean for an enterprise currently looking to digitally transform their business? To truly profit from the IoT, they will find themselves with millions of connected devices; located across the globe and accessed over a range of different mobile networks. Deploying, connecting, and managing these devices efficiently is not feasible for anyone to do manually. This is where a connectivity management platform with an automation engine can significantly lessen the admin burden. It can enable the enterprise to seek out new markets and new business models.
Automation engine: Set it and forget it
For an IoT deployment, basic connectivity management functions are needed around the clock, seven days a week, all year round. By automating these tasks, a business can respond immediately to changes in their network in real time. This is without requiring the personnel staff who is needed for extra resources working overtime.
The automation engine is built to constantly monitor network traffic for triggers. These are simple and rules set up by the business and tailored to their needs.
When a rule is triggered, the automation engine jumps into action, stepping in to manage the connection as required. If, for example, a subscriber does not connect for fifteen minutes, then you are notified. Companies are too often the last to know about issues with their devices. The reputation damage of the customer alerting you to a performance issue or device breaking can be severe. Catching an issue in fifteen minutes and being able to act proactively can make the difference between happy customers and disaster.
A diagram to show connectivity.Monitoring SIM connectivity helps catch problems quickly.
Trigger rules can be as simple or complex as required, built up by logical statements. To start off quickly, a range of common triggers are available as templates. These can include data usage and time-based triggers which send notifications or process SIM status or tariff changes.
Seamless management of eUICC
Automation is especially necessary for enterprises using reprogrammable embedded SIMs (eUICC). This is to deploy devices which switch a network operator remotely as they move from one location to another. By applying eUICC technology, the device usage is billed to the local network on the local rate. Typically, a lower rate than a roaming solution can offer. Automated geographical management means that no matter where in the world the device ends up, the data can be billed locally. The addition of eUICC campaign management makes it easy to roll out changes to large-scale deployments.
Automation drastically reduces the burden of changing operator with eUICC campaign management, with changes automatically rolled out across selected SIMs from a single action. The enterprise can activate, swap, and deactivate profiles on eUICC SIMs and simultaneously troubleshoot multiple eUICC SIMs remotely.
A diagram to show change profile.Automated profile switching saves on roaming costs.
Automation in action
The automation engine in Pelion Connectivity Management is so new that it is in beta. It is in a select group of pioneering companies within IoT. As the scale of the typical IoT deployment is set to increase dramatically over the coming years, automation becomes increasingly important. Pelion Connectivity Management is laying the groundwork for tomorrow’s IoT deployments, raising the bar on what level of automation is standard in IoT connectivity.
Most MVNOs
Other leading connectivity management platforms
Advanced automation engine  No automation engine  Automation engine
Real-time network monitoring  Lack of network integration required for real-time monitoring  Single network integration
eUICC automation No eUICC automation  No eUICC automation
Contact us to understand how you can bake in automation to your next IoT deployment.
Contact us
  • Arm Mali-C55: Image processing with the smallest silicon area and highest performance
    ParagBeeraka
    ParagBeeraka
    Arm Mali-C55 is the latest and most configurable image signal processor combining the highest image quality and performance with the smallest silicon footprint.
    • June 8, 2022
  • Arm introduces new high-performance Corstone Subsystems for MCU and A-class applications
    SamBruggen
    SamBruggen
    New Arm Total Solutions expand high-performance microcontroller and application use-cases with the latest Corstone subsystems for Cortex-M and Cortex-A
    • April 26, 2022
  • New Arm Virtual Hardware for the entire IoT ecosystem
    Stefano Cadario
    Stefano Cadario
    Read about the latest updates to Arm Virtual Hardware including new virtual devices from Raspberry Pi, NXP and ST to make the development process more accessible.
    • April 26, 2022
