Mobile, Graphics, and Gaming blog Mali Performance 2: How to Correctly Handle Framebuffers
  • Mali
  • performance
  • OpenGL ES
  • gpu
  • rendering
Peter Harris
Peter Harris
April 28, 2014
9 minute read time.
Previous blog in the series: Mali Performance 1: Checking the Pipeline
This week I take a slight diversion from the hardware-centric view of the rendering pipeline we have been exploring so far to look at how, and more importantly when, the Mali driver stack turns OpenGL ES API activity into the hardware workloads needed for rendering. As we will see, OpenGL ES is not particularly tightly specified around this area, so there are some common pitfalls which developers must be careful to avoid.
Per-Render Target Rendering: Quick Recap
As described in my previous blogs, Mali's hardware engine operates on a two-pass rendering model, rendering all of the geometry for a render target to completion before starting any of the fragment processing. This allows us to keep most of our working state in local memory tightly coupled to the GPU, and minimize the amount of power-hungry external DRAM accesses which are needed for the rendering process.
When OpenGL ES is used well we can create, use, and then discard most of our framebuffer data inside this local memory. This avoids the need to read framebuffers from, or write framebuffers to, external memory at all, except for the buffers we want to keep such as the color buffer. However this isn't guaranteed behavior and some patterns of API usage can trigger inefficient behavior which forces the GPU to make extra reads and writes.
Open GL ES: What is a Render Target?
In Open GL ES there are two types of render target:
  • On-screen window render targets
  • Off-screen framebuffer render targets
Conceptually these are very similar in OpenGL ES; although not entirely identical. Only one render target can be active at the API level for rendering at any point in time; the current render target is selected via a call to glBindFramebuffer( fbo_id ), where an ID of 0 can be used to switch back to the window render target (also often called the default FBO).
On-screen Render Targets
On-screen render targets are tightly defined by EGL. The rendering activity for one frame has very clearly defined demarcation of what is one frame and what is the next; all rendering to FBO 0 between two calls to eglSwapBuffers() defines the rendering for one frame.
In addition the color, depth, and stencil buffers in use are defined when the context is created, and their configuration is immutable. By default the value of the color, depth, and stencil immediately after eglSwapBuffers() is undefined - the old value is not preserved from the previous frame - allowing the GPU driver to make guaranteed assumptions about the use of the buffers. In particular we know that depth and stencil are only transient working data, and we never need to write them back to memory.
Off-screen Render Targets
Off-screen render targets are less tightly defined.
Firstly, there is no equivalent of eglSwapBuffers() which tells the driver that the application has finished rendering to an FBO and it can be submitted for rendering; the flush of the rendering work is inferred from other API activities. We'll look more about the inferences the Mali drivers support in the next section.
Secondly, there are no guarantees about what the application will do with the buffers attached to the color, depth, and stencil attachment points. An application may use any of these as textures, or reattach them to a different FBO, for example reloading the depth value from a previous render target as the starting depth value for a different render target. By default the behavior of OpenGL ES is to preserve all attachments, unless explicitly discarded by the application via a call to glInvalidateFramebuffer(). Note: this is a new entry point in OpenGL ES 3.0; in OpenGL ES 2.0 you can access the equivalent functionality via the glDiscardFramebufferExt() extension entry point which all Mali drivers support.
Render Target Flush Inference
In normal circumstances Mali flushes rendering work when a render target is "unbound", except for the main window surface which is flushed when the driver sees a call to eglSwapBuffers().
To avoid a performance drop developers need to avoid unneeded flushes which only contain a sub-set of the final rendering, so it is recommended that you bind each off-screen FBO once per frame and render it to completion in one go.
A well-structured rendering sequence (almost anyway - read the next section to see why this is incomplete) would look like:
#define ALL_BUFFERS COLOR_BUFFER_BIT | DEPTH_BUFFER_BIT | STENCIL_BUFFER_BIT
glClear( ALL_BUFFERS )    // Clear initial state
glDraw...( ... )          // Draw something to FBO 0 (window surface)
glBindFramebuffer( 1 )    // Switch away from FBO 0, does not trigger rendering
glDraw...( ... )          // Draw something to FBO 1
...                       // Draw FBO 1 to completion
glBindFramebuffer(0)      // Switch to FBO 0, unbind and flush FBO 1 for rendering
glDraw...( ... )          // Draw something else to FBO 0 (window surface)
glBindFramebuffer( 2 )    // Switch away from FBO 0, does not trigger rendering
glDraw...( ... )          // Draw something to FBO 2
...                       // Draw FBO 2 to completion
glBindFramebuffer(0)      // Switch to FBO 0, unbind and flush FBO 2 for rendering
eglSwapBuffers()          // Tell EGL we have finished, flush FBO 0 for rendering
By contrast the "bad" behaviour would look like:
glBindFramebuffer( 1 )    // Rebind away from FBO 0, does not trigger rendering of FBO
                          // However, rebinding FBO 1 requires us to reload old render
                          // state from memory, and write over the top of it
glBindFramebuffer(0)      // Switch to FBO 0, unbind and flush FBO 1 (again)
This type of behavior is known as an incremental render and it forces the driver to process the render target twice, the first processing pass will need to write all of the intermediate render state out to memory (color, depth, and stencil), and the second pass will read it back in from memory again so it can "append" more rendering on top of the old state.
Well-behaved one-pass render
As shown in the diagram above you can see that incremental rendering has a +400% bandwidth penalty [assuming 32-bpp color and D24S8 packed depth-stencil] in terms of the framebuffer bandwidth when compared against a well-structured single pass render which avoids the need to write and then re-read the intermediate state to and from main memory.
When to call glClear?
The observant reader will have noted that I inserted some calls to glClear() into the rendering sequence for our frame buffers. The application should always call glClear() for every attachment at the start of each render target's rendering sequence, provided that the previous contents of the attachments are not needed, of course. This explicitly tells the driver we do not need the previous state, and thus we avoid reading it back from memory, as well as putting any undefined buffer contents into a defined "clear color" state.
One common mistake which is seen here is only clearing part of the framebuffer; i.e. calling glClear() while only a portion of the render target is active because of a scissor rectangle with only partial screen coverage. We can only completely drop the render state when it applies to whole surfaces, so a clear of the whole render target should be performed where possible.
When to call glInvalidateFramebuffer?
The final requirement placed on the application for efficient use of FBOs in the OpenGL ES API is that it should tell the driver which of the color / depth / stencil attachments are simply transient working buffers, the value of which can be discarded at the end of rendering the current render pass. For example, nearly every 3D render will use color and depth, but for most applications the depth buffer is transient and can be safely invalidated. Failure to invalidate the unneeded buffers may result in them being written back to memory, wasting memory bandwidth and increasing energy consumption of the rendering process.
The most common mistake at this point is to treat glInvalidateFramebuffer() as equivalent to glClear() and place the invalidate call for frame N state at the first use of that FBO in frame N+1. This is too late! The purpose of the invalidate call is to tell the driver that that the buffers do not need to be kept, so we need to modify the work submission to the GPU for frame which produces those buffers. Telling us in the next frame is often after the original frame has been processed. The application needs to ensure that the driver knows which buffers are transient before the framebuffer is flushed. Therefore transient buffers in frame N should be indicated by calling glInvalidateFramebuffer() before unbinding the FBO in frame N. For example:
static const GLEnum invalid_ap[2] = { GL_DEPTH_ATTACHMENT, GL_STENCIL_ATTACHMENT };
glInvalidateFramebuffer( GL_FRAMEBUFFER, 2, &invalid_ap[0] ); // Only keep color
In this blog we've looked at how the Mali drivers1 handle the identification of render passes, the common points of inefficiency, and how an application developer can drive the OpenGL ES API to avoid them. In summary we recommend:
  • Binding each FBO (other than FBO 0) exactly once in each frame, rendering it to completion in a contiguous sequence of API calls.
  • Calling glClear() at the start of each FBO’s rendering sequence, for all attachments where the old value is not needed.
  • Calling glInvalidateFramebuffer() or glDiscardFramebufferExt() at the end of each FBO’s rendering sequence, before switching to a different FBO, for all attachments which are simply transient working buffers for the intermediate state.
Next time I'll look at a related topic to this one – the efficient use of EGL_BUFFER_PRESERVED for maintaining window surface color from one frame as the default input for the next frame, and the implications that has for performance and bandwidth.
Cheers,
Pete
The next blog in the series asks the question: is EGL_BUFFER_PRESERVED a good thing? Read it below.
Read next blog: Is EGL_BUFFER_PRESERVED a good thing?
Footnotes
  1. It is worth noting that little of this is actually Mali specific - most of the mobile GPU vendors make the same recommendations, so this is general best practice, irrespective of the underlying GPU.
  • Valentin Semernyov
    Valentin Semernyov over 6 years ago
    Hi Peter!
    Thanks for your time writing all these articles!
    1. It is also interesting how MALIs GPU handles shared depth/stencil attachments? For example,
    Fbo1 has attached Color texture1 and Depth texture0.
    Fbo2 has attached Color texture2 and Depth texture0.
    The sequence is:
    1. Bind Fbo1, clear color and depth and draw into it. Depth is read/write.
    2. Bind Fbo2, clear color only and draw into it. Depth is read/write.
    3. Bind screen fbo(0) and mix color texture1 and color texture2 in shader...
  • alek314
    alek314 over 7 years ago
    Hi Peter,
    Does invalidate the default framebuffer help save bandwith? For example:
    glInvalidateFrameBuffer( GL_DEPTH, GL_STENCIL )
    eglSwapBuffer()
    glInvalidaeFrameBuffer(GL_COLOR)
    Thank you.
  • Peter Harris
    Peter Harris over 8 years ago
    Yes, it should work exactly the same as a glClear() in terms of avoiding readback behavior.
    Cheers,
    Pete
  • Martin
    Martin over 8 years ago
    Belated question: will glClearBuffer() instead of glClear() also do the job ?
  • Peter Harris
    This might be resetting the invalid bit once either writeout or readback happens.
    There is no means to do this in the graphics API. The only mechanism to turn something from "invalid" into "valid" is by rendering something into it so it then has a well defined value. Any rendering to achieve this is, by definition, after the readback must have occurred.
    HTH,
    Pete
    Clay John
    Clay John
    Exploring advanced mobile GPU optimizations in Godot using Arm tools like Streamline and Mali Offline Compiler for real-world performance gains.
    • July 10, 2025
    Clay John
    Clay John
    • June 11, 2025
    Mina Dimova
    Mina Dimova
    • June 6, 2025
