Mobile, Graphics, and Gaming blog Introducing PyOpenCL
  • OpenCL
  • pyopencl
  • python
Anton Lokhmotov
Anton Lokhmotov
March 27, 2014
2 minute read time.
I will start my blog series with a subseries on technology that I know and come to love best - OpenCL from the Khronos Group. OpenCL aims to provide functional portability across computer systems comprised of general-purpose processors (e.g. CPUs) and special-purpose accelerators (e.g. GPUs), to which I will now and then refer to as accelerated systems.
OpenCL is often criticised for presenting a steep learning curve for software engineers but I don't think that's fair: the verbosity of the OpenCL API is really a consequence of its generality. Once you have written a couple of OpenCL programs, you realise that most of the code running on the host processor is actually boilerplate.
I will sidestep this verbosity of OpenCL altogether by using PyOpenCL - a neat Python module written by Andreas Klöckner. (If you are reading this Andreas, keep up the good work!)
Just install PyOpenCL and NumPy - and you are ready to roll!
In [1]:
import pyopencl as cl
import numpy as np
Trivial example
Suppose we want to create an array containing integers from 0 to 15.
In [2]:
N = 16
That's trivial using NumPy:
In [3]:
np_range = np.arange(N, dtype=np.int32)
np_range
Out[3]:
array([ 0,  1,  2,  3,  4,  5,  6,  7,  8,  9, 10, 11, 12, 13, 14, 15], dtype=int32)
but our PyOpenCL example will fill in a similar array using OpenCL:
In [4]:
cl_range = np.zeros(N, dtype=np.int32)
cl_range
Out[4]:
array([0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], dtype=int32)
Gimme some context!
Creating a context could hardly be easier:
In [5]:
context=cl.create_some_context()
Ditto creating a command queue:
In [6]:
queue=cl.CommandQueue(context)
Building and running
An OpenCL C program equivalent to np.arange(N) follows:
In [7]:
source = '''
kernel void arange(global int * buffer)
    const size_t gid = get_global_id(0);
    buffer[gid] = convert_int(gid);
The kernel will be launched as N work-items over a one-dimensional range [0, N-1]. Each work-item will get its unique index gid in the range (that is, an integer between 0 and N-1 inclusive) and write it into argument buffer at offset gid.
Let's build the program:
In [8]:
program = cl.Program(context, source).build()
allocate a memory buffer:
In [9]:
memory_flags = cl.mem_flags.WRITE_ONLY | cl.mem_flags.ALLOC_HOST_PTR
memory = cl.Buffer(context, flags=memory_flags, size=cl_range.nbytes)
launch the kernel:
In [10]:
kernel = program.arange(queue, [N], None, memory)
and copy the results from the buffer to cl_range:
In [11]:
cl.enqueue_copy(queue, cl_range, memory, wait_for=[kernel])
cl_range
Out[11]:
Finally, let's confirm that arrays np_range and cl_range match element-wise:
In [12]:
np.all(np_range == cl_range)
Out[12]:
True
Concluding remarks
I am very interested in getting feedback. I am aiming primarily at software engineers already familiar with OpenCL so I can jump straight to more advanced topics. But if you feel you like a little more explanation, just ask me: I will be happy to explain, or point you to some excellent learning resources out there, or indeed consider filling in details in my later posts...
Also, I prepared this post using the wonderful IPython Notebook environment ("Introducing PyOpenCL" as IPython notebook). I haven't seen much in the way of using PyOpenCL and IPython together, so would be very grateful for any links.
In my next post, I start discussing how to optimise OpenCL kernels for the ARM Mali-T600 and Mali-T700 GPU series.
  • Chris Varnsverry
    Chris Varnsverry over 11 years ago
    FYI there are also Mali based odroid boards available
  • Tom Gall
    Tom Gall over 11 years ago
    The ARM based Samsung Chromebook with a Mali T604 is a good choice.  I suspect the upcoming Chromebook 2 will also be a great choice but given the hardware isn't available yet it's too early. The Arndale board is also a good choice.
    I like the odroid boards but like the odroid-xu for instance doesn't include OpenCL support for Linux unless you sign an NDA with Imagination.
  • Tarik Saidani
    Tarik Saidani over 11 years ago
    Is there any affordable ARM Mali GPU/ OpenCL enabled that can be used for development?
  • Introducing the Model Gym: Training neural graphics models on Arm
    Annie Tallund
    Annie Tallund
    Discover how Arm’s Model Training Gym helps you train, fine-tune, and export neural graphics models for real-time rendering with PyTorch and ExecuTorch.
    • October 27, 2025
  • Introducing Arm Neural Graphics SDK for Game Engines and NSS plugin for UE5.4
    Willen Yang
    Willen Yang
    The Arm Neural Graphics SDK enables AI-powered upscaling and real-time rendering for modern game engines.
    • October 27, 2025
    Vidya Praveen
    Vidya Praveen
    • September 19, 2025
