Embedded and Microcontrollers blog White Paper: Custom SoCs Compete with Discrete IC Boards
  • subsystem
  • discrete
  • design
  • White Paper
  • soc_integration
  • soc
  • ip
  • ic
Eric Gowland
Eric Gowland
December 3, 2015
In this White Paper, commissioned by ARM, author and leading industry commentator John Blyler (jblyler), takes a look at the current economics of custom System-on-Chip development relative to discrete IC boards, and analyses just where the tipping point in favour of custom designs lies.
Excerpt
"Custom System-on-Chip (SoC) semiconductors have now reached a cost point to compete directly with traditional discrete IC board products. Many original electronic manufacturing (OEM) companies of printed circuit boards are reconsidering a SoC implementation as a way to reduce the bill-of-material (BoM) costs, shrink the product size and power consumption, and add new features such as wireless connectivity and sensor processing. Further, moving to a custom SoC has several inherent advantages, such as design IP protection, supply chain end-of-life (EoL) security and mitigating the slowing of Moore’s law."
Whitepaper_CustomASICEconomics.pdf
  • Eoin McCann
    Eoin McCann over 9 years ago
    Multi project wafer (MPW) make it even more compelling to build SoCs, it allows cheap prototyping, and even enables applications that require small quantities of products. http://info.sondrel.com/affordable-silicon-for-your-iot-ic-0
  • Ravinder
    Ravinder over 9 years ago
    Dynamics around  ASIC   vs  discrete board explained in a very simple language .
    Simon Tatham
    Simon Tatham
    • September 4, 2025
    Simon Tatham
    Simon Tatham
    • September 4, 2025
  • Adapting Kubernetes for high-performance IoT Edge deployments
    Alexandre Peixoto Ferreira
    In this blog post, we address heterogeneity in IoT edge deployments using Kubernetes.
    • August 21, 2024
