Architectures and Processors blog File not found when executing assembled program
  • not_found
  • Assembly
  • Android
  • linker
  • elf
  • execve
  • problem
  • linking
  • Linux
Myy
Myy
November 29, 2016
1 minute read time.
The main problem
When assembling your first programs with AS, and linking it to external libraries like this :
armv7a-hardfloat-linux-gnueabi-as -o test.o test.S
armv7a-hardfloat-linux-gnueabi-ld.gold --hash-style=sysv -o test test.o -lc
You might be confronted to this error when executing your program :
$ ./test
-bash: ./test: No such file or directory
Using strace to pinpoint the problem will result to something like this :
execve("./test", ["./test"], [/* 28 vars */]) = -1 ENOENT (No such file or directory)
write(2, "strace: exec: No such file or di"..., 40strace: exec: No such file or directory
) = 40
exit_group(1)                           = ?
+++ exited with 1 +++
Looking at execve manual page, ENOENT is described like this :
ENOENT The file filename or a script or ELF interpreter does not exist, or a shared library needed for the file or interpreter cannot be found.
The executable is not a script. The file clearly exists. However, the ELF interpreter ?
When running readelf -l elf_executable you can see which interpreter the executable tries to use. In this case, the output is :
Elf file type is EXEC (Executable file)
Entry point 0x81b8
There are 5 program headers, starting at offset 52
Program Headers:
  Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg Align
  PHDR           0x000034 0x00008034 0x00008034 0x000a0 0x000a0 R   0x4
  INTERP         0x0000d4 0x000080d4 0x000080d4 0x00013 0x00013 R   0x1
      [Requesting program interpreter: /usr/lib/libc.so.1]
  LOAD           0x000000 0x00008000 0x00008000 0x00208 0x00208 R E 0x1000
  LOAD           0x000208 0x00009208 0x00009208 0x000cc 0x000cc RW  0x1000
  DYNAMIC        0x000208 0x00009208 0x00009208 0x000a0 0x000a0 RW  0x4
Section to Segment mapping:
  Segment Sections...
   00
   01     .interp
   02     .interp .dynsym .dynstr .hash .gnu.version .gnu.version_r .rel.plt .plt .text
   03     .dynamic .data .got
   04     .dynamic
The line Requesting program interpreter shows which ELF interpreter the system tries to use. On this system /usr/lib/libc.so.1 does not exist, which is why executing the program returns "File not found".
However, on a Linux system for example, the standard ELF interpreter is not libc but ld.
The solution
Define the system dynamic linker as the ELF interpreter using the --dynamic-linker directive when linking the program.
When linking programs for Linux ARM systems :
armv7a-hardfloat-linux-gnueabi-ld.gold --hash-style=sysv --dynamic-linker=/lib/ld-linux-armhf.so.3 -o test test.o -lc
When linking programs for Android ARM systems :
armv7a-hardfloat-linux-gnueabi-ld.gold --hash-style=sysv --dynamic-linker=/system/bin/linker -o test test.o -lc
  • Myy
    Myy over 7 years ago
    I just encountered the same issue while trying to cross-compile a C program from a system using GlibC and execute it on a system using Musl.
    Musl dynamic  linker is located at : /lib/ld-musl-armhf.so.1 on ARMv7 with Hardware FPU.
    So you'll have to pass -Wl,--dynamic-linker=/lib/ld-musl-armhf.so.1 to GCC, when linking an executable, to be able to execute the program correctly on the Musl system.
    Example :
    arm-linux-gnueabihf-gcc -o test test.c -Wl,--dynamic-linker=/lib/ld-musl-armhf.so.1
    Christoffer Dall
    Christoffer Dall
    • April 28, 2025
    Joh
    Joh
    • April 8, 2025
    Samer El-Haj-Mahmoud
    • January 28, 2025
