DS-5 Add license fails at developer account login
I have an Altera Arria V SOC Development kit.
I am attempting to activate the ARM DS-5 license that is provided with the kit, but for some reason it fails at the last step.
I have created an ARM account, and can use it successfully to log into the ARM website, but when I attempt to add the license (press the 'finish') button, it fails with the following error:
     Unable to login. Check email address and password are correct.
I know the address and password are correct, so what is going on here? I have tried creating another account with a different e-mail address, but that doesn't work either. I am now being prevented from doing productive work while I attempt to license something that I've already paid for.
I don't know if the diagnostics are of value here, but I'll attach them anyway:
System Information:
  OS name: Windows XP
  Java version: Java HotSpot(TM) Server VM, 20.10-b01
  PATH environment variable: C:/altera/13.1/embedded/ds-5/bin/../sw/eclipse//../java/bin/server;C:/altera/13.1/embedded/ds-5/bin/../sw/eclipse//../java/bin;C:/altera/13.1/embedded/ds-5/bin/../sw/eclipse//../java/lib/i386;C:\altera\13.1\embedded\ds-5\bin;C:\altera\13.1\embedded\ds-5\sw\java\bin;C:\altera\13.1\quartus\bin;C:\altera\13.1\quartus\sopc_builder\bin;C:\altera\13.1\embedded\host_tools\altera\preloadergen;C:\altera\13.1\embedded\host_tools\altera\mkpimage;C:\altera\13.1\embedded\host_tools\altera\device_tree;C:\altera\13.1\embedded\host_tools\gnu\H-i686-pc-mingw32\bin;C:\altera\13.1\embedded\host_tools\gnu\H-i686-pc-cygwin\bin;C:\altera\13.1\embedded\host_tools\mentor\gnu\arm\baremetal\bin;C:\altera\13.1\embedded\host_tools\python;C:\altera\13.1\embedded\ds-5\bin;C:\altera\13.1\embedded\host_tools\cygwin\bin;C:\altera\13.1\embedded\host_tools\cygwin\bin;C:\Documents and Settings\t0033863;
Product Information:
  Version: 5.15.0
  Build number: 5150018
  Build date: 201306
  Selected toolkit: none
  ARM_DS_TOOLKIT_KEY environment variable: not set
  arm.ds.toolkit.key system property: not set
Host IDs:
  D4BED99268D8: Intel(R) 82579LM Gigabit Network Connection
Licenses are searched for in the following locations:
  ARMLMD_LICENSE_FILE environment variable: "C:\Documents and Settings\t0033863\Application Data\ARM\DS-5\licenses"
  LM_LICENSE_FILE environment variable: not set
  DS-5 licenses directory: "C:\Documents and Settings\t0033863\Application Data\ARM\DS-5\licenses"
I'd appreciate any help with this.
