Compilation Error "sh: C:\Program: No such file or directory" in DS-5 eclipse project
Hello Everyone,
I am getting the following compilation error “sh: C:\Program: No such file or directory" in DS-5 eclipse setup. I am able to compile single source file individually but when select the project to complete then getting this error
Environment: Window
ARM Compiler 5.04
DS500-BN-00003-r5p0-17rel1
If I change Builder Type (inside Project Setting-> C/C++ Build-> Builder Setting)   to "Internal Builder" then I am able to compile the project but I have to build using "External Builder" option.
Could you please provide input to resolve this error
