Error: C9932E: Cannot obtain license for Compiler (feature compiler5) with license version >= 5.0201301
hellow  everyone! I meet a problem when i develop in ds-5,
I have setup Xilinx SDk and DS-5 on my PC,and I fellow xilinx xapp1185's guide to import xilin's driver file into ds-5.
in xapp1185's 1st step,when i change compiler option to armcc&armar, the err displayed as fellow:
Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Feature:       compiler5
Filename:      C:\flexlm\license.dat
License path:  C:\flexlm\license.dat;
FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
Cannot obtain license for Compiler (feature bsp_compiler5) with license version >= 5.0201301
Feature:       bsp_compiler5
ARM C/C++ Compiler, 5.03 [Build 24]
make[1]: *** [xadcps_selftest.o] 错误 1
Feature:       compiler5
make[1]: *** [xadcps_sinit.o] 错误 1
make[1]: 由于错误目标libs”并未重新创建。
"Compiling cpu_cortexa9"
ERROR:EDK -  make failed for target "libs"
ERROR:EDK - Error(s) while running make.
make: *** [ps7_cortexa9_0/lib/libxil.a] 错误 2
make: 由于错误目标all”并未重新创建。
11:12:51 Build Finished (took 8s.533ms)
  • Hi liuhz,
    In DS-5, what do you see if you go to Help > ARM License Manager and then look at the Configuration and Diagnostics tabs?
    It's also worth checking that you have the correct version of DS-5 selected in the "Select the toolkit that you intend to use" dropdown.
    There's another similar question from earlier in 2013 that might help out: DS-5 bsp compiler 5 license
    Hope this helps,
    Joe
  • Adding to what Joe said, the key bit of the error is:
    "Cannot find license file."
    and
    "License path:  C:\flexlm\license.dat;"
    This tells you where the tool was looking for your license (C:\flex\license.dat) and why it failed (looks like the file doesn't exist).
    So in the License Manager you need to make sure that you've added your license file (or server) and that the path is correct.
