how to indicate a rootfs on FastModel
I'm trying to run linux arm64 kernel on fast model. I followed the page https://wiki.linaro.org/HowTo/BuildArm64Kernel
After all steps, I had got linux-system-foundation.axf and linux-system.axf.
then I use command as below:
model_shell cadi_system_Linux64-Debug-GCC-4.1.so   linux-system-foundation.axf
The console complained that I didn't indicate a right root path. I had download the pre-built root filesystems
from Linaro Releases, But I don't know how to use it.
Cound anyone help me? thank you!
VFS: Cannot open root device "vda2" or unknown-block(254,2): error -6
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(254,2)
Call trace:
