Introducing section within a section in WinARM GCC tools...
This question is on using WinARM, GCC and mainly on loader (.ld).  Please pardon me if the post does not suit the thread.
I am using WinARM GCC tools for compiling, linking the code for LPC2378 (NXP Controller). This worked great until recently. Now I need to put some signature in LPC2378 at particular location to make it Code read protection.
Earlier my .ld file looks like
  ROM (rx) : ORIGIN = 0x00000000, LENGTH = (512k-4k)
  RAM (rw) : ORIGIN = 0x40000000, LENGTH = (32k-32)
and with LPC2378 requirement of putting the signature of 0x12345678 at location 0x1FC I modified the .ld file as below
MEMORY
  CRP_ROM (rx) : ORIGIN = 0x000001FC, LENGTH = 4
SECTIONS
  /* place "myArray" inside "m_my_memory" */
  .crpsection :
    . = ALIGN(4);
    KEEP(*(.crpsection*));
    . = ALIGN(4);
  } > CRP_ROM
  /* first section is .text which is used for code */
   .text :
/* *crt0.o (.text) */           /* Startup code */
/*KEEP (crp.o(.constdata))*/
KEEP(*(.vectorg))
KEEP(*(.RESET))
KEEP(*(.SWI_HANDLER))
. = ALIGN(4);
KEEP(*(.init))             /* Startup code from .init-section */
*(.text .text.*)           /* remaining code */
*(.gnu.linkonce.t.*)
*(.glue_7)
*(.glue_7t)
*(.gcc_except_table)
*(.rodata)                 /* read-only data (constants) */
*(.rodata*)
*(.gnu.linkonce.r.*)
. = ALIGN(4);
  } > ROM
  /***** old:
  .text :
    *crt0.o (.text)
    *(.text)
    *(.rodata)
    *(.rodata*)
    *(.glue_7)
    *(.glue_7t)
  } > ROM
created a crp.c file with content
#define CRP1 0x12345678
__attribute__((section(".crpsection"))) unsigned int const Security_Value = CRP1;
and added this makefile
SRC =  $(TARGET).c monitor.c adc.c crp.c
With this I get an error saying
c:/winarm/bin/../lib/gcc/arm-elf/4.1.2/../../../../arm-elf/bin/ld.exe: section .crpsection [000001fc -> 000001ff] overlaps section .text [00000000 -> 0000b23b]
c:/winarm/bin/../lib/gcc/arm-elf/4.1.2/../../../../arm-elf/bin/ld.exe: main.elf: section .crpsection lma 0x1fc overlaps previous sections
Basically I want to reserve memory location 0x1FC for CRP value. This is basically putting a section inside a section.
Is it possible to do this way in WinARM - GCC tools sets? Or is there any other way to do this? Generally I look at generated .bin file to see the signature of 0x12345678 at location 0x1FC.
Any thoughts/ suggestions are helpful
With best regards,
Phani.
