Recovering from a hard fault cortex M3
I'm new into  mixing C and ASM on Cortex M3 using keil, here is the question,
Suppose that a function tries to access some memory that is not in the system, something like this, the system crashes with the hardfualt exception, so my question is why after executing the hardfault the program reenters the hardfault again, is there a way to simply return to the next instruction
here is my sample code
#include "LPC17xx.h"                    // Device header
int main(void)
    SCB->SHCSR |= 0x00007000; // enable Usage Fault, Bus Fault, and MMU Fault
    SCB->CCR |= 0x18; // enable div-by-0 and unaligned fault
    int i=0;
    static int test;
    test = (*(unsigned int *)0x678000000);
    while(1)
        i++;
int value;
void HardFault_Handler (void)
    int r1,;
    value=r1;
    __asm
Any ideas?
