loadfile option for 32 bit access only
I use the loadfile command in DStream to laod program elf that contains code and data for several cores (M4, A53,..) and also some extensa core.
For this core the data must be written on 32 bits only.
It sounds the loadfile just write bytes.
Other debugger have option to load data in long format, so is there the equivalent on DS5?
Or if not is it possible to generate an ELF with 32 bit words and not 8 bits words?
thanks
claude
No Data
