Is there another way to install opencl or to use arm compute library without opencl?
I'd like to manipulate GPU to neural net.
My environment is odroid-xu4 that constructed with exynos5422(cortex-15, cortex-7, mali-t628GPU) and TIZEN OS based linux kernel
i googled about GPU, they recommended using OpenCL and Arm compute library
Fortunately arm provides libOpenCL.so for android and linux on this link(https://developer.arm.com/products/software/mali-drivers/user-space)
I thought that TIZEN use libOpenCL.so as it is because Tizen OS based linux kernel. but it doesn't work properly..
I have successfully compile OpenCL example, The executable file prints error message(error while loading shared libraries: /lib/libOpenCL.so: internal error)
Is there another way to install opencl OS agnostic or to use compute library without OpenCL?
