Cortex M0 internal Failure solution for ALU, CPU and Register rong results
Hello All,
I am using Cortex M0 based controller and want to know if the following issues can happen and what can be the possible solution by software to handle the issues:
1. ALU resulting wrong result run time.
2. Register access giving wrong results run time
3. Memory access (RAM or ROM) giving wrong results run time.
Thanks in advance!!
