Cortex-A5 sets instr_pc to 0x00000008 after enabling MMU and using high exception vectors
Hello Community,
in our current ASIC project we have to replace an ARM926EJ-S with a Cortex-A5.
In the moment we are facing the following problem in our bootloader:
We intend to use the high exception vectors after reset (input vinithi is tied fix to '1') as our external DDR memory is mapped at address 0x00000000 and is normally not available during the early bootup phase.
After configuring and enabling the MMU (according to "Migrating a software application from ARMv5 to ARMv7-A/R, Application Note 425, topic 4.1) we see the value 0x00000008 in register instr_pc several times and some time later the core performs a read access to address 0x00000000 and the system stalls as the DDR2 controller isn't configured yet.
If we configure the DDR2 controller so that the memory at address 0x00000000 is available, the application is running as expected.
Also is we configure the mmu table entry for 0x00000000-0x000FFFFF to NOACCESS, the application is running.
But we want/need to understand the behavior.
Any suggestion what we are missing and why the core is accessing 0x00000000?
Thank you!
Daniel
