In the excellent textbook ARM System Developer's Guide: Designing and Optimizing System Software (Andrew N. Sloss, Dominic Symes, Chris Wright - Elsevier, 2004) there is example on the page 115:
int checksum_v6(int *data) { unsigned int i; int sum=0; for (i=64; i!=0; i--) { sum += *(data++); } return sum; }
that is disassembled (according to authors) in the following code:
checksum_v6
MOV r2,r0 ; r2 = data
MOV r0,#0 ; sum = 0
MOV r1,#0x40 ; i = 64
checksum_v6_loop
LDR r3,[r2],#4 ; r3 = *(data++)
SUBS r1,r1,#1 ; i-- and set flags
ADD r0,r3,r0 ; sum += r3
BNE checksum_v6_loop ; if (i!=0) goto loop
MOV pc,r14 ; return sum
I reproduced this example, and what I've got this:
checksum_v6 PROC
MOV r2,r0
MOV r0,#0
MOV r1,#0x40
|L1.48|
LDR r3,[r2],#4
ADD r0,r0,r3
SUB r1,r1,#1
CMP r1,#0
BNE |L1.48|
BX lr
ENDP
As you can state (highlighted in red) in my version of disassembly instead of one conditional execution instruction (that is more efficient) compiler placed 2 instructions: SUB and CMP.
I've tried with all optimization options but couldn't reproduce book authors disassembly.
Does exist some flag that regulates such kind of things ?
Thanks in advance.
Pavel
