Why Cortex-R5 Bus-ECC documentation different from Cortex-R7
Hello Support,
In the Cortex-R5 TRM [Section 9.1.1 -- Bus ECC -- Chapter is  Level Two Interface] I see the following statement:
It is possible that fatal, that is double-bit, ECC errors
might cause more data corruption. This can result in the CPU operating on corrupted data, or
behaving unpredictably, based on corrupted control or response signals.
In the Cortex-R7 TRM [Section 11.1 -- About L2 Interface] I am unable to find anything similar to above related to Bus ECC,
Can you please help me understand whether Bus ECC within Cortex-R7 implementation doesn't have that limitation as Cortex-R5 for AXI Level 2 Master Interface?
Thank you.
Regards
Pashan
