__main, ADR address
IDE: KEIL(4.74.00)
MCU: STM32F103VET6
问题:地址为0x08000138的那一行执行结果 为什么是0x08000164 ?
0x0800012E 0800      DCW      0x0800
                 HardFault_Handler:
0x08000130 F000F802  BL.W     __scatterload (0x08000138)
0x08000134 F000F83A  BL.W     __rt_entry (0x080001AC)
                 HardFault_Handler:
0x08000138 A00A      ADR      r0,{pc}+4  ; @0x08000164
0x0800013A E8900C00  LDM      r0,{r10-r11}
0x0800013E 4482      ADD      r10,r10,r0
0x08000140 4483      ADD      r11,r11,r0
0x08000142 F1AA0701  SUB      r7,r10,#0x01
                 HardFault_Handler:
0x08000146 45DA      CMP      r10,r11
0x08000148 D101      BNE      0x0800014E
0x0800014A F000F82F  BL.W     __rt_entry (0x080001AC)
0x0800014E F2AF0E09  ADR.W    lr,{pc}-0x07  ; @0x08000147
0x08000152 E8BA000F  LDM      r10!,{r0-r3}
0x08000156 F0130F01  TST      r3,#0x01
0x0800015A BF18      IT       NE
0x0800015C 1AFB      SUBS     r3,r7,r3
0x0800015E F0430301  ORR      r3,r3,#0x01
0x08000162 4718      BX       r3
0x08000164 3274      DCW      0x3274
0x08000166 0000      DCW      0x0000
0x08000168 3294      DCW      0x3294
0x0800016A 0000      DCW      0x0000
                 HardFault_Handler:
0x0800016C 3A10      SUBS     r2,r2,#0x10
0x0800016E BF24      ITT      CS
0x08000170 C878      LDM      r0!,{r3-r6}
0x08000172 C178      STM      r1!,{r3-r6}
0x08000174 D8FA      BHI      __scatterload_copy (0x0800016C)
0x08000176 0752      LSLS     r2,r2,#29
0x08000178 BF24      ITT      CS
0x0800017A C830      LDM      r0!,{r4-r5}
0x0800017C C130      STM      r1!,{r4-r5}
0x0800017E BF44      ITT      MI
0x08000180 6804      LDR      r4,[r0,#0x00]
0x08000182 600C      STR      r4,[r1,#0x00]
0x08000184 4770      BX       lr
0x08000186 0000      MOVS     r0,r0
                 HardFault_Handler:
0x08000188 2300      MOVS     r3,#0x00
0x0800018A 2400      MOVS     r4,#0x00
0x0800018C 2500      MOVS     r5,#0x00
0x0800018E 2600      MOVS     r6,#0x00
0x08000190 3A10      SUBS     r2,r2,#0x10
0x08000192 BF28      IT       CS
0x08000194 C178      STM      r1!,{r3-r6}
0x08000196 D8FB      BHI      0x08000190
0x08000198 0752      LSLS     r2,r2,#29
0x0800019A BF28      IT       CS
0x0800019C C130      STM      r1!,{r4-r5}
0x0800019E BF48      IT       MI
0x080001A0 600B      STR      r3,[r1,#0x00]
0x080001A2 4770      BX       lr
                 HardFault_Handler:
0x080001A4 B51F      PUSH     {r0-r4,lr}
                 HardFault_Handler:
0x080001A6 BD1F      POP      {r0-r4,pc}
                 HardFault_Handler:
0x080001A8 B510      PUSH     {r4,lr}
                 HardFault_Handler:
0x080001AA BD10      POP      {r4,pc}
                 HardFault_Handler:
0x080001AC F003F8DC  BL.W     __user_setup_stackheap (0x08003368)
0x080001B0 4611      MOV      r1,r2
                 HardFault_Handler:
0x080001B2 F7FFFFF7  BL.W     __rt_lib_init (0x080001A4)
                 HardFault_Handler:
0x080001B6 F001FDA7  BL.W     main (0x08001D08)
0x080001BA F003F8FA  BL.W     exit (0x080033B2)
                 HardFault_Handler:
0x080001BE B403      PUSH     {r0-r1}
                 HardFault_Handler:
0x080001C0 F7FFFFF2  BL.W     __rt_lib_shutdown (0x080001A8)
                 HardFault_Handler:
0x080001C4 BC03      POP      {r0-r1}
0x080001C6 F003F8FF  BL.W     _sys_exit (0x080033C8)
0x080001CA 0000      MOVS     r0,r0
   151:                 LDR     R0, =SystemInit
0x080001CC 4809      LDR      r0,[pc,#36]  ; @0x080001F4
   152:                 BLX     R0
0x080001CE 4780      BLX      r0
   153:                 LDR     R0, =__main
0x080001D0 4809      LDR      r0,[pc,#36]  ; @0x080001F8
   154:                 BX      R0
   155:                 ENDP
   156:
   157: ; Dummy Exception Handlers (infinite loops which can be modified)
   158:
   159: NMI_Handler     PROC
   160:                 EXPORT  NMI_Handler                [WEAK]
0x080001D2 4700      BX       r0
   161:                 B       .
   162:                 ENDP
   163: HardFault_Handler\
   164:                 PROC
   165:                 EXPORT  HardFault_Handler          [WEAK]
0x080001D4 E7FE      B        NMI_Handler (0x080001D4)
   166:                 B       .
   167:                 ENDP
   168: MemManage_Handler\
   169:                 PROC
   170:                 EXPORT  MemManage_Handler          [WEAK]
0x080001D6 E7FE      B        HardFault_Handler (0x080001D6)
