PMU in arm11 results
I am programming raspbery pi model b ARM1176 bare metal (in assembly and c). I need to calculate the clock cycles used to execute an assembly code.
I am using the following code for PMU counter:
  1.   mov r0,#1
  2.   MCR p15, 0, r0, c15, c12, 0 ; Write Performance Monitor Control Register
  3.   /* Reset Cycle Counter */
  4.   mov r0,#5
  5.   MCR p15, 0, r0, c15, c12, 0 ; Write Performance Monitor Control Register
  6.   /* Meaure */
  7.   MRC p15, 0, r0, c15, c12, 1 @ Read Cycle Counter Register
  8.   <MY CODES>
  9.   MRC p15, 0, r1, c15, c12, 1 @ Read Cycle Counter Register
From this if I have
add r3,#3
in place of my code i get r1=8 and r0=0, which seems correct since arm11 has 8 pipeline stages and it takes 8 clock cycles to execute it.
But when I add more instructions I am getting ridiculous results like
add r3,#3
add r4,#1
r0=0,r1=97/96/94 (the result of r1 should also be constant!!!)
I am using uart to see results of registers on minicom. I have aatached my code files
10261.zip
