UEFI variables from UEFI shell
I have a device which has UEFI on it along with UEFI shell and the UEFI pups up at startup and allows the user to interact with the system preOS boot running some UEFI services. I want to write a UEFI application in which I will have a variable created and set to some value inside the UefiMain entry point function.
In the future on my system I will have some routines execute or not in the UEFI environment based on the value of this variable.
As a test I want to first create the application in which I set the variable and run it by UEFI firmware before the UEFI shell pops up and then read the value of that variable from UEFI shell with some UEFI service API. Is that possible? Is it enough to put the application inside the EF partition and it will be run by UEFI before UEFI shell pops up?
I am reading through the UEFI specifications now and it seems to be possible altough I am new to UEFI and I am not sure whether when you put an UEFI application inside the ESP partition this will get run before or after UEFI shell pops up. Please tell me if this is possible and if this is the correct way to do it. Thank you.
