Hello Experts,
Reading armv8 documentation, I understand that switching between execution states require a change of exception levels. I would like to know if I can mix Aarch32 and Aarch64 userspace binaries within a process in the following manner:
1. User space Aarch32 binary (EL0) invokes sys call.
2. Kernel (EL1, Aarch64 code) sets up EL0 stack for Aarch64 and return to a specific address that falls in a Aarch64 shared library. (EL0 LR is set to a different return address)
This of course assumes that the sys call is a new implementation in the kernel that also takes care of Aarch64 ABI before returning to userspace. If this isn't feasible, are there other ways we can get 32-bit and 64-bit binaries within the same process to work atop 64-bit kernel?
Thanks for reading.
Hi Prem,
This is deliberately not allowed - processes have to be 32 (compat) or 64 (native), and no mixing. I'm not sure what you're trying to do, but it'll definitely need 2 separate processes sorry.
Hi Ben,
Thanks for your response. This matches what I read as well.
To help me understand this better, would you please point out which step below will fail:
1. A32 user space code (Processor mode = Aarch32) invokes sys call to jump to kernel.
2. Kernel sets SPSR_EL1 mode (M[4] bit) to Aarch64 and ELR_EL1 to point to userspace A64 code (64-bit binary already mapped in the process address space).
3. Kernel sets SP_EL0 to a newly allocated stack area.
4. Invoke ERET from kernel.
Won't this take us back to EL0 (userspace) with the processor in Aarch64 mode capable of executing A64 instructions? I am ignoring ABI details here.
Again, thanks a lot for looking at this.
Linux specifically forbids this mixing AArch32 and AArch64 within a process, but the architecture does not (since there's no such thing as "a process" architecturally). So if you're making your own kernel, this could be done.
So typically you wouldn't want to do this because of other issues it would cause, and there's potentially a bunch of other things you'll need to do or handle to cope with it. But architecturally it's possible.
Thanks Ben.
