When trying to compile the ADuCM355 examples I get the same error as many others have reported: eg. M355_ECSns_CycloVoltammetry.sct(7): error: L6236E: No section matches selector - no section to be FIRST/LAST. There are many warnings but this is the only error.
I have tried all the suggested solution both on this and other forums. On the other hand, the examples do work with the IAR evaluation tool. I assume this is because the IAR tool does support AC5. I cannot afford a licence for Keil with AC5 or a license for IAR.
Best regards
David
I recommend to contact the Analog Devices Support team accordingly:
https://www.analog.com/en/support.html
Hi David, please open a Support Ticket with a reference to this post to receive a time-limited license key for test purposes:
https://www.arm.com/support/contact-support
Update:
Time-limited license keys are no longer available.
If you now require Arm Compiler 5 access, it is necessary to order a Keil MDK Professional User-Based License (UBL):
https://developer.arm.com/Tools%20and%20Software/Keil%20MDK#Editions
