Dear ARM Support Team,
I hope this message finds you well.
I am currently experiencing an issue with my MDK-ARM Professional license. I have successfully registered the license using the LIC code provided, and I have installed ARM Compiler 5 (version 5.06 update 7) in the following directory:
C:\Users\user\AppData\Local\Keil_v5\ARM
However, after completing the installation, I noticed that the license file was not generated. As a result, I am unable to check out a license, and I am receiving the following error:
Could you please advise on how I can generate the necessary license file or provide further guidance on resolving this issue?
Thank you for your assistance.
Best regards,Hyunbae Lee
The eval license does NOT support the legacy compilers.
